1.6L conversion??
  • 1704 Views
1.6L conversion??
« on: February 22, 2007, 06:20:53 AM »
85 samurai 1.3L i would like a bigger engine and it seems to be sounding like putting a 1.6 in to from a tracker?? how hard is it to do and what kind of mods do you have to do. eg. electrical, vacuum lines etc.
Offline blakester1123
  • 95
  • 88 sammy 6in on 32s and rising
Re: 1.6L conversion??
« Reply #1 on: February 22, 2007, 08:23:00 AM »
easiest way to do it is to find an actual donor vehicle i got a rolled tracker with 130,000 on it for 250 bucks on ebay everything still worked in it too. I ended up using a lot of parts from it also.
« Reply #2 on: February 22, 2007, 09:39:52 AM »
At the very least try and get all the 1.6 bits and pieces, dizzy,  starter motor etc.. I am using all 1.3 parts on a 1.6 engine and not much fits without a little modification here and there. If you're not running a lift and extended bump stops you will need to modify the sump and oil pickup. If you run EFI then a few bucks spent at trail Tough will make life a lot easier. Here in the UK we had a carb 1.6 which makes life simpler.
