sidekick spool info
  • 25 Replies
  • 5411 Views
Offline ChileKick
  • 75
  • DIYer Man !
    • Nacion 4x4
sidekick spool info
« on: December 21, 2004, 01:13:57 AM »
Hi everyone , I'm thinking about building my own rear spool but have a couple of doubts regarding the size , and as my sidekick is 91 carbureted I was wondering if the rear axles in newer (94-up) have the same size or number of teeth in the axle itself the ones that couple with the spool on each side , does anybody know?
thanks
Custom 5" suspension lift,custom 2"body lift, custom transmision lift,custom intake porting and custom exhaust.
3" wider A-arms custom made front coils.Power inverter , dual batteries , 8000lb winch , VHF , AM , LSB , On board Notebook-GPS on 15" Screen :-)
 265/70 - 15 tires on 8 rims. Custom Man
Offline hcgalvin
  • 1695
    • Granite Path
Re: sidekick spool info
« Reply #1 on: December 21, 2004, 01:54:41 AM »
Yes, the rear is the same in all sidekick and tracker models. They are 26 spline. The only ones that are different are the fronts.
The only thing that really changes in the rear is the differential ratios, if you have a manual, you most likely have 5.12 gears, if you have a 3 speed auto, you have 4.62's, and if you have a 4 speed auto (overdrive) you have the 5.12's.
Also, there are 10 bolt and 12 bolt rear ends. Usually 92+ are 12 bolt (most of them with ABS brakes in the rear) and 91- 89 are usually 10 bolt.
I understand you are going to make one, I'll tell you that purchasing one will only cost you $99 bucks, otherwise, why not just weld the rear? (lincoln locker)
« Last Edit: December 21, 2004, 01:57:10 AM by hcgalvin »
Heather Galvin
Offline 1bigtracker
  • 3409
« Reply #2 on: December 21, 2004, 03:19:23 AM »
did it, now 2 sets of axle shafts into it and it only get 100 road miles a year!  have hed it welded for 2 years.  i like it because of traction but hate the tire ware and road manners.
stu
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: December 21, 2004, 03:22:55 AM »
stu
Yeah, I was popping shafts left and right with the spool in my truck.
Heather Galvin
« Reply #4 on: December 21, 2004, 04:20:14 AM »
Some new info, it was there all the time
I just noticed it  ::)
The 3 speed auto Trackers with a 16V
engine came with 4.30 diff gears, I don't
know if the SideKicks came that way also,
I would assume so but ???
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #5 on: December 21, 2004, 05:48:37 AM »
I'd never heard of 4.30 at all. I know overseas you get 4.88's... I wonder if the other poster is absolutely sure.
Heather Galvin
« Reply #6 on: December 21, 2004, 07:06:15 AM »
I have a set of 4.30's and a set of 4.88's, I think the 4.30's were a california only type of thing for the smog standards(so many rev's per mile) they look strong!
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: December 21, 2004, 07:42:16 AM »
 :P
So much yet I have to learn... when you think you know it all..
Thanks for the info.
Heather Galvin
« Reply #8 on: December 21, 2004, 10:18:12 AM »
I got the info from the USDOT spec sheet
for the 94 GEO Tracker, listed under 16V
engine drive line specs (California specs)
« Last Edit: December 21, 2004, 11:37:41 AM by wildgoody »
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #9 on: December 21, 2004, 11:34:23 AM »
    My truck had 4.30's  :) now it's got 5.12's  ;D  big difference mines a '95 16v tracker 3 speed auto I don't know if it's california emissions or not it was originaly purchased in buffalo NY
   I was thinking of putting a spool in it over the winter but I'm having second thoughts especialy after hearing about broken shafts :o is it really that much harder on the shafts than say a powertrax locker ???
At Lakeview Motorsports, were wasting your time already!
« Reply #10 on: December 21, 2004, 11:40:02 AM »
A locker, will ratchet and allows some
differential effect, a spool does not and
twists alxes or slips a tire
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #11 on: December 21, 2004, 11:52:13 AM »
Yep, 4.30 is California emissions only.
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #12 on: December 21, 2004, 01:41:22 PM »
^^^TRUE!^^^
What ratio did the 1.3 Sidekicks have? I forgot but I now it was low.
« Reply #13 on: December 21, 2004, 10:14:50 PM »
I think a 5.62 :-/
« Last Edit: December 21, 2004, 10:15:03 PM by Zukipilot »
Offline explosivo
  • 3157
« Reply #14 on: December 21, 2004, 10:17:13 PM »
I think a 5.62 :-/
5.38 I believe... but he said it was a 91, didn't he? ???
omghi2.us[/url]
