Miracle Tracker
  • 16 Replies
  • 4685 Views
Miracle Tracker
« on: December 20, 2004, 05:27:48 AM »
Here it is ladies and gentlemen. The miracle Tracker. At 38 miles per gallon it claims the title for worlds best gas mileage from a Tracker ::)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4513470958&category=6242&sspagename=WDVW
« Last Edit: December 20, 2004, 05:28:01 AM by Zukipilot »
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: Miracle Tracker
« Reply #1 on: December 20, 2004, 05:35:36 AM »
It's a two wheel drive, that's why. ;) ;D
« Last Edit: December 20, 2004, 05:36:14 AM by TN_Tracker »
mperry
Re: Miracle Tracker
« Reply #2 on: December 20, 2004, 07:51:29 AM »
In his dreams.  :P 2WD get maybe 31MPG.
I figure it's one o' those rigs... drive it one way, push it back.  ::)
Offline SnoFalls
  • 1358
Re: Miracle Tracker
« Reply #3 on: December 20, 2004, 08:37:38 AM »
or he has "toy" axels ... roll it back and forth 10 times, and it goes without the engine running :) (aka "stomper")
Offline TN_Tracker
  • 1113
Re: Miracle Tracker
« Reply #4 on: December 20, 2004, 09:15:02 AM »
Yep, I actually saw an E-bay ad with a quote of 34 mpg for a 4wd. ::) I wish. ;D
Offline Speedracer7c
  • 2210
Re: Miracle Tracker
« Reply #5 on: December 20, 2004, 10:51:06 AM »
lol, I get better mileage now then i did when it was stock. Except my range is a little decreased from the huge dent in the tank.  :o
Offline TN_Tracker
  • 1113
Re: Miracle Tracker
« Reply #6 on: December 20, 2004, 11:09:26 AM »
... Except my range is a little decreased from the huge dent in the tank.  :o
Oops ;)
Offline jzap
  • 515
  • How difficult can it be?
Re: Miracle Tracker
« Reply #7 on: December 20, 2004, 01:33:02 PM »
The best I've ever done with my 4wd '96 is 30mpg.  That's with the tires pumped tp 32psi and driving it like I have an egg between my foot and the gas pedal.
If the tires are at factory spec of 23 psi, the mileage drops down to about 25mpg.  It's a trade off.  At 32psi it rides like a rock.
But, 38?  Maybe it's within the realm of possibility, but he's in Colorado Springs, and I doubt it at that altitude.  I guess not all fairy tales begin with, "Once upon a time..."
If only it weren't so PURPLE...
« Last Edit: December 20, 2004, 01:34:30 PM by jzap »
Jim Z.
66 Apache camper
Re: Miracle Tracker
« Reply #8 on: December 20, 2004, 02:54:35 PM »
Maybe she lived in a town that was down hill the whole way ;D
Re: Miracle Tracker
« Reply #9 on: December 20, 2004, 09:45:30 PM »
What fun would that be with no hills to climb ::) Oh yea it is a 2wd :P My 2wd never got much over 30, much less pushing 40.
« Last Edit: December 20, 2004, 09:45:49 PM by Zukipilot »
Offline 1bigtracker
  • 3409
Re: Miracle Tracker
« Reply #10 on: December 21, 2004, 03:30:05 AM »
what if you put all those things you see around that say they increase MPG  like the Tornado air swirl thingy, K&N filter, header, one of thoe thing you zip tie onto your fuel line, ect.  think you could get 38 MPG?  i think mabey
stu
Re: Miracle Tracker
« Reply #11 on: December 21, 2004, 04:38:48 AM »
I knew a guy that installed two gas
savers, one was a 50% and one was
a 60% for a total of 110% gas savings  :o
He had to stop every 30 miles or so and
drain his gas tank
Offline Salice_q
  • 9
  • If life gives you a challenge wheel over it!
Re: Miracle Tracker
« Reply #12 on: December 21, 2004, 04:41:16 AM »
Mine pushes ALMOST 20.  There is somethin wrong with it but I have no clue what.  The new tires made it worse and also just found a huge dent in my tank ::)whoops 8)
I gots me a 89 tracker, future lift is 1 1/2" coil spacers
Offline chet
  • 556
  • Zuki time!
Re: Miracle Tracker
« Reply #13 on: December 21, 2004, 04:58:26 AM »
maybe they used imperial gallons! ;D 38 MPG Imp = 31 MPG US. Still kinda high!
mperry
Re: Miracle Tracker
« Reply #14 on: December 21, 2004, 12:33:31 PM »
stu
Some of those devices work OK on some of the older carbed engines, but I doubt you'll see any improvement in a modern engine that's running moderately well.
About the only thing that might help a Zuki engine would be a turbo charger or reshaping fuel flow. (Not including the obvious... lightening the vehicle and over-airing the tires. <g>)
