vitara v6 springs on 1.6 16v 5 door???
  • 10 Replies
  • 3726 Views
Offline 4maddog
« on: April 20, 2007, 11:05:05 AM »
hi any of you guys know if springs off a 1997-98 2.0 v6 vitara will fit a 1993 1.6 16v 5 door vitara? if so is the ride hight the same? i think they will fit but not too sure :-\ cheers
ITS ONE LIFE LIVE IT
Offline cj
  • 1276
  • I drive a really big ATV
Re: vitara v6 springs on 1.6 16v 5 door???
« Reply #1 on: April 20, 2007, 03:27:33 PM »
Yes, they fit.
Offline 4maddog
« Reply #2 on: April 21, 2007, 03:16:58 AM »
thanks are they the same hight as normal springs? sorry ;D
« Reply #3 on: April 23, 2007, 07:38:01 AM »
No, you'll gain between 2-3" of lift.  The front strut mounts will need to be flipped, and the rear will need longer shocks.  Write up is on ZW.
« Reply #4 on: April 23, 2007, 12:38:11 PM »
Is it JUST the front springs that fit, or all four? How is the ride with vitra springs as compaired to the wagoneer or aftermarket springs?
Offline cj
  • 1276
« Reply #5 on: April 23, 2007, 02:14:44 PM »
You'll get minimal lift. I even tried them on a swb and it is not worth the effort  IMHO. You would get more lift from the later GV V6 as they are a bit heavier which is what Yankee Tim is referring to.
« Reply #6 on: April 23, 2007, 05:54:09 PM »
Okay, I just think a spring lift makes more sense (more travel) than a spacer. I know I would have to get OME struts to take advantage of extra travel... but if I'm going to go through the trouble of lifting, I want more artriculation while I'm at it. Since this is a DD I'm concerned about ride quality of the springs out there. Not much info out there saying what springs are best to use :(
« Reply #7 on: April 24, 2007, 12:56:47 PM »
Some people prefer softer springs, some harder. Almost all off road Zuks are different and so are their nose/tail weights which make a lot of difference to ride and to height. Some people are running spacers, some aren't. Wheel offset makes a difference to effective spring rate too. Then theres cost and how much you want to pay. There just isn't a 'best' spring. All you can do search back through the many posts, ask a few questions and then make an educated guess as to what will suit you best.
« Reply #8 on: April 24, 2007, 02:25:27 PM »
Yeah, it's just hard 'cause there's not a good thread out there with a compilation of info. A lot of the other threads are missing specifics.... like when to use front's and when to use rears, what springs are stiffer (I know Calmini's are stiff) and which are softer... Jeep or Vitra? How much does spacing affect the spring rate? Etc etc.
Anyway - just wish they'd make one thread where people talk about their specific setups, what affected them....
I'll be adding some custom bumpers with 2" receiver front / rear for my winch and taking my best guess as to what springs to get later. I know I'm going to want longer springs for my kick for more articulation... my best guess at this point is to get some Jeep springs (which ones?) and use spacers in front or rear to level it out as appropriate?
Offline cj
  • 1276
« Reply #9 on: April 24, 2007, 02:59:44 PM »
Sounds like you need to be a bit more specific in your request for info if you want a specific answer. tell us what model you have, what accessories you will have on it (weight plays a part), what you're wanting to use it for, what size rubber you want to run, rim width and offset, etc., etc. and then you may get some answers relating directly to your needs as there are plenty of options, some better than others and some cheaper and then you can choose which way to go. I've run a few variations of Kicks and setups and they all have pluses and minuses depending on where you're coming from.
« Reply #10 on: April 27, 2007, 04:51:56 PM »
Goals (in order of priority):
* Reliability
* Maintain daily driveability
* Rubicon Ready
* Have to throw in - spend as little as possible  ::)
Ways I can think to accomplish goals: (please note these are my opinions from reading these threads, and I'm open to what everyone has to recommend)
Recovery & safety equipment (Winch - have 9000i warn already, high lift jack, CB, fire extinguisher, first aid kit, basic tools, maybe on-board welder)
31" MT tires
  That aren't too loud for Daily Driving
  Much bigger seems to make them daily drive poorly, cause more breakage, and gets
  exponentially more expensive?
Lift / cut / backspace wheels to accommodate 31" tires
  Want any lift to add more articulation. So longer springs / shocks / struts - prefer to avoid
  spacers, and won't do a body lift unless absolutely necessary.
Body armor
  Rocker panels
  Front bumper w/ 2" receiver & d-rings
  Rear bumper w/ 2" receiver & d-rings
  Front skid plate
  Gas tank skid plate
  Pumpkin caps & axle shaft armor? Can this be done on kicks?
Dual t-cases (as this seems to be the only way to lower high range in my 5 speed?) with stock
  t-case gearing. And / Or add a turbo to counteract the power taken away from 31" tires and
  added weight of armor.
I'll be making custom front and rear (with tire swing-away) bumpers, so not sure the weight yet. I'm doing my best to engineer them to be light, but still protect the kick. They'll have 2" receiver so I can pull the winch in my apartment (stuff gets stolen here :( ) when not needed... and so I can run the winch off the back if I have to. I'll be getting nylon rope, so hopefully the winch will be lighter and only sag the front / back an extra inch or so when it's on?
So, from what I gather, I'll need 2-3" of lift... so... what do you all think?
