How much gear lube in t case/for track/kick?
  • 2493 Views
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« on: April 26, 2007, 11:44:43 AM »
My check bolt is stripped and dont know how much/many jugs of gear lube to put in my t case. I just did a rebuild with 4to1 gears and dont want to have not enough of gear lube in there.
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
DAC1138
Re: How much gear lube in t case/for track/kick?
« Reply #1 on: April 26, 2007, 09:10:32 PM »
I bought 4 quarts for the t-case and the gearbox when I changed out my clutch. I'd say 2 full quarts went into the gearbox and it took more than the other 2 to fill up the tcase. I haven't filled the tcase yet, I'm going to do that later, but i put the remaining 2 quarts I had in and it still wasn't full. But, as I said, it was all I bought so I left it at that. I'd say it needs 3 quarts, buy 4 just to be safe.
Offline BigPig
  • 276
« Reply #2 on: April 27, 2007, 09:57:59 AM »
Factory owners manual calls for 3.6 pints (1.7 liters), which is what DAC1138 says.
'89 Sidekick w/ 4.5" of lift.
« Reply #3 on: April 27, 2007, 03:18:54 PM »
If I can piggyback this thread... anyone here use some molly oil like Red Line?
http://www.myoilshop.com/AutoPrds.html
Offline olija
  • 770
    • Check out my cardomain
« Reply #4 on: April 27, 2007, 07:54:50 PM »
I tried to loosen the fill plug on the transfer case before I drained it but I couldn't get it loose at all. Tried heating it up and cooling it down with water and using an impact driver...nothin doin.  I had the same problem on my rear diff but we used an air chisel to remove the plug. The difference between the diff and the t-case is the t-case is aluminum so it will get ruined alot easier than a steel rear diff. Anyone got any suggestions?
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #5 on: April 27, 2007, 09:11:02 PM »
Long ago, one of the guys at a Jiffy Lube stripped mine, and he managed to dig around below and found something that fit. I think it was off a Nissan or something, but it had an actual head on it, so I could use a socket wrench on it. Hum. I don't have that case anymore to tell you what it is. :(
Heather Galvin
Offline olija
  • 770
« Reply #6 on: April 28, 2007, 09:25:40 PM »
Yeah I'd be inclined to use some sort of internal hex bolt on there instead of this square hole crap. It just strips out way too easily.
