Sidekick Transfer Cases
  • 1747 Views
Offline Deathrunner
  • 33
  • Don't have a zuk, but a man can dream...right?
« on: May 13, 2007, 12:10:33 AM »
Simple Question.
Is the 1.8 liter sport t case and tranny different from the 1.6L transfer case and tranny.
More Specifically, will the Calmini tcase gears fit in a 1.8L tcase?
T.O.Y.O.T.A.
Take Off Yer Oversized Tires A$$hole
Re: Sidekick Transfer Cases
« Reply #1 on: May 13, 2007, 01:34:32 PM »
I think they would fit, the yokes might be a diffrent spline count but other than that I do not see any diffrence in the x-fer case, the trans you have to grind back the input shaft a little bit for the pilot bearing to go on a little further to fit a 1.6 or vise versa, I know that they are real close, the x-fer case might take a diffrent oil seal on the yokes but if you know the application for it your good to go.
Offline Deathrunner
  • 33
« Reply #2 on: May 14, 2007, 06:49:48 AM »
Cool, but, will Calmini's transfer case 4.24:1 gears fit in a 1.8Liter tranfers case?
If not, does anyone make gears for this transfer case?
T.O.Y.O.T.A.
