CHANGING THE FRONT CONSTANT VELOCITY JOINT GAITER (CV JOINT)
  • 11 Replies
  • 2896 Views
from_wales
HI CAN ANY ONE ADVISE ME HOW TO CHANGE THIS CV JOINT GAITER. ON A VITARA.
I HAVE REMOVED THE DRIVE SHAFT.
THANKS
JEREMY
« Last Edit: June 16, 2007, 08:56:58 AM by from_wales »
Re: CANGING THE FRONT CONSTANT VELOCITY JOINT GAITER (CV JOINT)
« Reply #1 on: June 16, 2007, 07:56:54 AM »
Pull the gaiter back. Underneath all the grease there is a circlip the needs to be removed to allow the CV joint to be seperated.
from_wales
« Reply #2 on: June 16, 2007, 07:59:29 AM »
IS THAT AT THE END THAT GOES TO THE WHEEL, OR THE END THAT GOES TO THE AXEL?
THANKS
JEREMY
« Reply #3 on: June 16, 2007, 08:15:06 AM »
Its been a while since I did one. I'm pretty sure theres one at both ends.
from_wales
« Reply #4 on: June 16, 2007, 08:16:40 AM »
THANKS
JEREMY
from_wales
Re: CHANGING THE FRONT CONSTANT VELOCITY JOINT GAITER (CV JOINT)
« Reply #5 on: June 16, 2007, 08:35:10 AM »
CANT FIND NO CIRCLIP.
THERE'S A BEARING WITH 6 BALLS, WITH A STAR SHAPED DRIVE SHAFT IN IT.
ANY IDEAS?
THANKS
JEREMY
« Last Edit: June 16, 2007, 08:57:49 AM by from_wales »
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #6 on: June 16, 2007, 10:17:04 AM »
I'm trying to remember too, but i'm pretty sure you have to remove the cv and boot from the wheel end, then slide the boot from the diff end down and off the other end.  Only one end of the CV will have the 1" diameter hole to pull the boots off correctly.  There is a circlip in there somewhere, but i can't remember where exactly.
Anyway, remember you have to start from the wheel end and work your way backwards into it.
1993 4-door Sidekick
4.24:1 t-case
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #7 on: June 16, 2007, 01:13:36 PM »
I thought that I had replied to this...
Try this article:
http://www.acksfaq.com/cvhalfshaft.html
Hope this helps!
Ack
from_wales
« Reply #8 on: June 16, 2007, 02:55:07 PM »
THANKS FOR YOUR HELP
JEREMY
from_wales
« Reply #9 on: June 17, 2007, 02:51:13 AM »
ALL DONE NOW, THANKS FOR ALL YOUR HELP.
FOR REFERENCE: THE CIRCLIP IS ON THE END CLOSEST TO THE AXEL.
THANKS AGAIN
JEREMY
Offline crikeymike
  • 713
« Reply #10 on: June 17, 2007, 09:55:26 AM »
THANKS AGAIN
JEREMY
Technically, you're working on an axle.  Do you mean closer to the diff end?
4.24:1 t-case
from_wales
« Reply #11 on: June 17, 2007, 10:09:48 AM »
YES I DO.
THANKS
JEREMY
