90 sidekick ignition
  • 1693 Views
fuddmanlehman
« on: August 02, 2007, 06:03:30 PM »
I have a 90 Sidekick w/manual tranny.  All of a sudden I cannot turn the key.  Suggestions from anyone- I don't want to spend $180 for a new switch unless I have to.  Turning the wheel doesn't work, turning the key over doesn't work.  Are switches from Samurai, or god forbid trackers interchangeable?
« Last Edit: August 02, 2007, 06:11:01 PM by fuddmanlehman »
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
Re: 90 sidekick ignition
« Reply #1 on: August 02, 2007, 06:07:30 PM »
Since you edited your post I edited mine.  ;D
Switches from sidekick and trackers are interchangable.
« Last Edit: August 02, 2007, 06:41:00 PM by wheresmyhat »
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #2 on: August 02, 2007, 09:01:44 PM »
Whats the deal with the tracker man, same vehicle different badge
kingzoo
« Reply #3 on: August 03, 2007, 09:00:07 AM »
   Go to a salvage yard and get one for cheap .Around here trackers are more plentiful than Sidekicks.
« Reply #4 on: August 03, 2007, 10:41:18 AM »
The lock is probably broken but have you tried some WD40 or similar?
