Aluminum Rims
  • 15 Replies
  • 4004 Views
Offline Sami88
  • 45
Aluminum Rims
« on: January 16, 2004, 04:39:50 AM »
Has anybody ever painted these and how did it turn out?
88
Re: Aluminum Rims
« Reply #1 on: January 16, 2004, 06:27:12 AM »
I painted my chrome ones, not sure why alum. would not come out ok?  just clean them well and make sure that they are warm! spray a real light coat first let it dry for a few minutes then have at it. If the wife is not around you could use the oven!
Offline Kreg
  • 795
    • Island 4x4
Re: Aluminum Rims
« Reply #2 on: January 16, 2004, 06:57:36 AM »
You have to etch aluminium with a chemical in order to paint it, otherwise the paint will just flake off.
Offline Sami88
  • 45
Re: Aluminum Rims
« Reply #3 on: January 16, 2004, 07:02:58 AM »
What type of Chemical and where can you get it?
Offline Kreg
  • 795
    • Island 4x4
Re: Aluminum Rims
« Reply #4 on: January 16, 2004, 07:11:59 AM »
We have it at the shop that I work at, where we make aluminum boats and various other equipment.
I'll go see what its called tomorrow and post the name of the chemical here.
Offline Sami88
  • 45
Re: Aluminum Rims
« Reply #5 on: January 16, 2004, 08:28:12 AM »
Thanks alot.  Could you take a wire brush and scuff them up good?
88
Offline Cowtracker
  • 39
Re: Aluminum Rims
« Reply #6 on: January 16, 2004, 01:52:32 PM »
I work at Freeman marine we make aluminum boat parts mostly doors and hatches.
The painting process involves a cleaning with Zepalume (kinda of an acid wash)  then sprayed with a alodine (sp) solution.
 after the parts dry they are primered like regular steel and painted ect.
Zepalume is a product of Zep Mfg I am not aware of it's proper chemical name. I don't know if alodine has a proper name either.
Guitars,zukes and hilbilly music!
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Aluminum Rims
« Reply #7 on: January 16, 2004, 02:14:13 PM »
"Guitars,zukes and hilbilly music! "  HEY ANOTHER DWIGHT FAN....... ;D
Offline Cowtracker
  • 39
Re: Aluminum Rims
« Reply #8 on: January 16, 2004, 02:27:31 PM »
Dwight um yea  dude has some pipes! . Actualy I am realy just a guitar nut / amature musician .
hey  here is some more useless trivia :D Suzuki also makes guitars and harmonicas? the guitars are,  (yawn) OK  but the hamonicas are some of the  best !
Re: Aluminum Rims
« Reply #9 on: January 16, 2004, 02:57:45 PM »
could you just use vinigar, like they do on galvanized stuff?
Offline Z3bra
  • 273
Re: Aluminum Rims
« Reply #10 on: January 17, 2004, 12:10:05 AM »
They make pianos too if I recall correctly.
Back to the original subject moreso, I believe Alodine is the tradename for the product but I don't remember what it actually is other than a primer/sealer for aluminum.  You generally use it after you chemically wash the aluminum to remove the surface oxide layer.
« Last Edit: January 17, 2004, 12:10:58 AM by Z3bra »
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Aluminum Rims
« Reply #11 on: January 17, 2004, 04:24:30 AM »
Go to the local auto paint store and tell them what you want to do.  They'll hook you up.
32 MTR's Warn 8000i
Offline Sami88
  • 45
Re: Aluminum Rims
« Reply #12 on: January 20, 2004, 04:01:10 AM »
Thanks for all the info guys.  I'll try and get something worked out.
88
Offline joezuki
  • 133
  • zukiworld rocks!
Re: Aluminum Rims
« Reply #13 on: November 18, 2004, 01:21:04 AM »
just started reading through... saw your post. On my aluminum rims, i used commercial aircraft stripper, sandblasted them, then painted them with lacquer paint without priming them. it's now 6 months later and even with chemicals & pressure washing to remove the brake dust, they still look great.  i used silver metallic lacquer from advance auto parts.
SpinalTap
Re: Aluminum Rims
« Reply #14 on: November 18, 2004, 05:12:23 AM »
Thought about powder coating them? Doesn't cost much and is a pretty tough finish.
