16 valve sammy swap.
  • 1799 Views
nerd
« on: October 11, 2007, 04:14:19 AM »
hi i just joined this forum and recently bought a 1988 tin top samurai with a bad engine...ive found a 4 door tracker in a junk yard and i want the engine out of it...what all should i take from the 4 door to complete the swap?  besides the engine haha
Offline SnoFalls
  • 1358
Re: 16 valve sammy swap.
« Reply #1 on: October 11, 2007, 07:41:05 AM »
wiring harness,
ECM (if you wanna run EFI)
Power Steering pump and box (if it has it)
nerd
« Reply #2 on: October 11, 2007, 08:11:27 AM »
do i need the power steering stuff? im not planning on making the samurai have power steering
« Reply #3 on: October 11, 2007, 10:46:35 AM »
You don't need the power steering stuff but its nice to have  ;D. Grab the speedo as well if you're fitting EFI because you'll need the vehicle Speed Sensor which is screwed on the back of the speedo head. Make sure you get the ECU on its bracket with all the relays attached.
nerd
« Reply #4 on: October 11, 2007, 12:01:48 PM »
awesome....thanks for all the input keep it comming
