What to buy for my exhaust?
  • 29 Replies
  • 6049 Views
Offline 99Trackerconv
  • 430
  • I love my Tracker
« on: November 11, 2004, 11:05:19 AM »
I just got my bonus check from work and need a new exhaust and tires. Tires are taken care of but I need to ask what you guys would do about the exhaust?
I would like to get the most parts for the least amount of money.(wife reasons)
I would like to get a new Catalytic converter, and muffler. Any brands yous suggest?
I want to have a nice deep tone. Not a bumblebee-in-a-can.
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
Re: What to buy for my exhaust?
« Reply #1 on: November 11, 2004, 11:18:30 AM »
I know a lot of guys on here run Flowmaster, but I've had better luck with Dynomax. What size of pipe you running? If you are running stock pipe, there's not much you can do for performance mufflers (2 inch is a good start there) and replacing an entire system can get expensive. Mine was 300 bucks Canadian. It was a worthy swap for me cause I busted my (already new) stock sized exhaust while wheeling. My wife was not happy, but at least she went for the bigger pipe size!
steveo
  • 430
  • I love my Tracker
« Reply #2 on: November 11, 2004, 11:24:17 AM »
well I would like to replace the cat, muffler and pipes too. I was thinking about going with 2.25 pipe if I could.
Offline 92Sidekick4x4
  • 1456
« Reply #3 on: November 11, 2004, 12:13:56 PM »
id go with a 2.25 inch flowmaster
« Reply #4 on: November 11, 2004, 02:05:44 PM »
Why replace the cat ???
you have a newer trucklet and
cats are expensive, just get a
muffler shop to install a new
2" cat back with a muffler, ask
them what they have for sound,
I had a quiet muffler put on, and
it still had some engine sound, the
whole system cat back cost $175
  • 430
  • I love my Tracker
« Reply #5 on: November 11, 2004, 02:13:16 PM »
Well the cat is pretty rusty and the heat sheild was rattling bad so I tried to take it off but the bolts were soooo rusted they fell apart and so I had to tear the bottom shield off and the top is still there and rattling bad too. I figured it was time to get a new one because of that and it also has almost 75K miles on it.
Either I'll get a new one or keep the old one weld the top sheild back on and gutt it after I the the cat-back exhaust is installed.
I'm kinda going with what I will need to get in the worst case scinerio
« Reply #6 on: November 11, 2004, 02:17:20 PM »
Ahh, I C
Offline zukiboy
  • 42
  • Wheel Forever !!!
« Reply #7 on: November 11, 2004, 02:52:35 PM »
I put a Thorley header and high flow cat and a magnaflow with a 2" tailpipe. Runs alot better and has a nice little rumble to it. :)
88 sami
3"lift 30's
No matter where you are there you'll be
Offline jerryp58
  • 449
« Reply #8 on: November 11, 2004, 10:47:45 PM »
I've been happy with the Calmini cat-back system, but I was dropping my daughter's car off at the shop yesterday and had the Tracker sitting there idling (waiting for my daughter) and the guy asked me if I wanted "a muffler put on that thing"  ::)
If you need to replace your CC, I'd go with a nice hi-flow one.
Jerry
  • 430
  • I love my Tracker
« Reply #9 on: November 12, 2004, 01:41:42 AM »
Can't buy a header for a 99+ cause I can't afford to pay for it.  :'(  $250-300 for a header from Austrailia  (Calmini doesn't make a header or cat-back system for the 99+ 4cyl)
How much will a high-flow cat cost? (I figured $80-100)
Thats what I was planning on getting if I have too.
I'd like to get dual exhaust but only if I keep the old cat. (I'd split it after the muffler.)
I told the wife that it souldn't cost more than $300-400 and she is complaining.  ::) So I have to get the most for the least amount of $$$ but also replace what is needed too.  >:(
« Last Edit: November 12, 2004, 01:47:39 AM by 99Trackerconv »
« Reply #10 on: November 12, 2004, 02:34:19 AM »
I was quoted $300 for a complete
3" turbo back system with a 3" cat
and no muffler.
I don't need a muffler because the
turbo and the cat mellows out the
sound so much it just has a nice
deep tone, not ricey in the least bit
Offline r3cc0s
  • 321
« Reply #11 on: November 12, 2004, 02:42:08 AM »
Question
I too own a newer 03" style tracker
I want to raise the pipe that is basically the main concern on my mind when traversing water
so should I look towards cutting the bumper and getting a pipe pointed through?
« Reply #12 on: November 12, 2004, 02:49:34 AM »
Don't worry about water, it won't
go in to the engine, but if you want
to get your pipe up and away from
rocks and obsticles, I would put it
out over the bumper, or thru the
bumper if it's in the way, that is going
to be where mine comes thu.
Right now it blows out under the trucklet
between the tire and the fuel tank, works
fine, I suck lots of exhaust fumes but it
can't get snagged on anything there  ;)
Offline r3cc0s
  • 321
« Reply #13 on: November 12, 2004, 02:57:27 AM »
being such a small displacement engine at 2.0
is a 2" exhaust necesasary?
like hot damn that's pretty decent size won't it affect back pressure?
I already find the 134lb torque reasonable to move my 4 door 03' through rough terrain
I wouldn't want to give any of it up for horsepower gains at higher rpms
« Reply #14 on: November 12, 2004, 03:01:04 AM »
I thought the 2.0L exhaust was
a good size system, I wouldn't
change it if it's in good condition,
just re-route it for clearance if needed
