87 samurai not running right cant figure it out.
  • 2508 Views
87sammibob
« on: December 09, 2007, 06:45:55 AM »
hi i have a 87 samurai so it is carbed and it always ran great then last night when i was crusing like 55 mph in 4th gear it would start to choke out and sputter i would try and rev it up to clear it but it would die then i would start it up again and it would run fine for a min or so then it would do the same thing? and advise it sounds tome like its leaning out . like maybe my secondaries arent kicking in or fuel pump i dont know if fuel pumps do that tho i thought they just die  thnaks guys
Freak
Re: 87 samurai not running right cant figure it out.
« Reply #1 on: December 09, 2007, 01:07:29 PM »
If you have'nt replaced your fuel filter in a while try that! It's been years since I had a carbed sammy but I used to find that the fuel bowl would get dirt and sediment in it.
 When off roading or hitting road bumps at high speeds the fuel would slosh and stir up the crap in the bowl and it would clog the jets. It would sputter and usually clear itself out. But it wouldn't be long until it would happen again!
 Like I said it's been years but if I remeber correctly it's fairly simple to take the bowl off the carb and clean it and the jets!
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #2 on: December 09, 2007, 03:43:43 PM »
You might also try taking the air cleaner off and spraying some carb cleaner down there. Then try reving it up pretty good and put your hand over the opening and see if you can suck what ever if anything might be hanging up in one of the passages. It will probably die when you do it. I think it's called the redneck carb cleaning.  That's what I would try first (after checking out the fuel filter). Also check all your vacuum hoses and make sure none have vibrated loose.
I've had a fuel go out kind of slow before. It could be the fuel pump but you hate to just start throwing parts at her. Hawk will sell you a new mechanical fuel pump pretty cheap as will the dealer.  Hawk adds shipping >:( Chain auto parts stores wanted more when I've tried them in the past. I think the going rate is around $42.00. :-\
-Adam
87 sammi
« Reply #3 on: December 09, 2007, 05:09:58 PM »
i had that exact same problem. i would be driving normally, on the road and it would slowly start to die and then just choke out completely, i would wait a few mins and it would start right back up but do the same thing. i had a garage look at it, they charged me 91 bux and told me they had no idea. let me know if you figure this out. good luck!!
« Reply #4 on: December 09, 2007, 07:57:33 PM »
I agree that it sounds like leaning out. Change out your fuel filter (it's hiding under truck near passenger tire) - do the redneck carb clean (you can take out the long stud with pliers - makes it easier to cover the hole in your carb).
If this doesn't fix it - I'd look more towards the fuel pump. It COULD be electrical (bad coil / coil wire?), but sounds like it's leaning out, and is a fuel issue to me.
ace69247no13
« Reply #5 on: December 14, 2007, 11:07:55 PM »
I had the same problem with my 87 tt turned out to be a loose ground on the firewall behind the battery
dicedaniels
« Reply #6 on: January 06, 2008, 05:49:47 PM »
yea i remember. took us a while though. thought we were stranded for a minute.
