tracker lift
  • 2048 Views
tracker8v4x4
tracker lift
« on: December 20, 2007, 03:56:34 PM »
i know the 4 door sidekcik springs are longer but are the shocks longer to or just mounted lower
Offline olija
  • 770
    • Check out my cardomain
Re: tracker lift
« Reply #1 on: December 20, 2007, 07:08:13 PM »
The extra weight makes a 4 door with 4 door springs sit the same height as a 2 door with 2 door springs.
Offline Uncivilized
  • 1469
    • Car Domain
Re: tracker lift
« Reply #2 on: December 20, 2007, 08:40:57 PM »
I don't think they're that much longer, the 4-doors have a slightly higher spring rate which makes them longer without compression, the lighter 2-door doesn't compress them as much so you get a smidge of lift. I think it's only about .5".
SP1086
Re: tracker lift
« Reply #3 on: December 20, 2007, 11:03:03 PM »
Yeah I had the LWB front springs in my SWB for a while as I needed a harder one due to the weight of the winch & bullbar.
I got Calmini's now so its all good.
I wouldnt put the LWB springs in unless you plan on carrying more weight.. Eg Bullbars Winch rear Bar ect..
If you are just doing it for the lift don't as it will be way too hard of a ride. Just get some spring spacers for a cheap lift option.
