fender clearance
  • 15 Replies
  • 4192 Views
big_kountry21
fender clearance
« on: February 03, 2008, 07:23:09 PM »
i'm workin on gettin my trak trail worthy and i'm havin trouble with the fenders clearin when flexed
MUD CHILD
Re: fender clearance
« Reply #1 on: February 03, 2008, 11:59:10 PM »
Start cutting
big_kountry21
« Reply #2 on: February 04, 2008, 12:01:28 AM »
i'm not very good at that...... what would be the tool of choice?
« Reply #3 on: February 04, 2008, 12:56:03 AM »
Sawzall!  :)
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #4 on: February 04, 2008, 10:54:23 PM »
cutting wheel might give you a little more finesse. be sure to tape off the area first so that you at least have a clue where you will be cutting.
and I bet you used a sawzall there drone :P
Mean Green Wheeling Machine
big_kountry21
« Reply #5 on: February 04, 2008, 11:08:13 PM »
angle grinder?... i was contemplating the cutting wheel. i'm not skilled enough for the sawsall
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #6 on: February 08, 2008, 05:16:30 AM »
HVAC tin snips ~ They are like kindergarden siccors for Track Kick owners.
BUt you need the good name brand ones.  Pawn shops have them used / cheap, but check the jaws for paly and abuse to the cutting edge.
Red for right hand / turn
Green for left hand / turn
Yellow for straight cut
Best, most accurate fender metal cutting fab tool out their.
big_kountry21
« Reply #7 on: February 08, 2008, 07:37:21 AM »
thanks i'll lokk for some.
« Reply #8 on: February 08, 2008, 05:55:50 PM »
We had plenty of finesse when cutting.  Heck, it even looked nice and straight for the first time I used it.
Then it kind of went downhill...  :D
big_kountry21
« Reply #9 on: February 08, 2008, 06:09:39 PM »
nice
Offline bashzuk
  • 784
« Reply #10 on: February 08, 2008, 11:31:41 PM »
When the heck did you do that to your rig??? and why did you go to 35's
Offline Amilla
  • 1076
« Reply #11 on: February 09, 2008, 08:04:58 AM »
I have trimmed a bunch of my buddies fenders for them.
I started using a cutoff wheel, then tried using a little air saw. It worked pretty good, some of the thick on my buddies XJ were a little  tough but it was doubled up sheetmetal.  So im sure these little saws would work great on the sami's and sidekicks.
Amilla
spyder0069
« Reply #12 on: February 09, 2008, 09:36:38 AM »
I used an angle grinder with cuttoff wheel.  I didn't chop the top of my fenders though so most of my work was straight lines.  I just widened the bottom front and rear for steering clearance.  Then I used angle aluminum and riveted to the cut pieces of fender so I still had lip to rivet my fender flares to and so I could reuse the original plastic dust shield that goes along the inside.
« Reply #13 on: February 09, 2008, 12:15:08 PM »
Did it late last year when I had to buy a new set of tires.  I actually decided to say with the 33's, I don't break that much anyway and rarely found something I couldn't climb over with the BFG's.  Now I just need to clean up and paint the rest of the rig...
ultra-rebel
« Reply #14 on: February 09, 2008, 04:13:01 PM »
Hey Big  this was my first attempt with a sawsall and a cutting wheel
Not to much finesse lol...   the cutting wheel seemed a little easier I used a 4" grinder with a worn out metal cutoff saw blade
Cheers
Rebel
