erratic steering
  • 1829 Views
Offline Chief
  • 678
  • Whaddya lookin at??
erratic steering
« on: February 17, 2008, 04:50:28 PM »
I have P/s on my tracker, but it's weird. Sometimes it works ok, but it also sometimes like I have manual steering, no power at all. The system was low, but I filled it back up, but still the same. It normally does it when I'm not moving or going very slow, like manual steering. Suggestions?
Re: erratic steering
« Reply #1 on: February 17, 2008, 06:53:06 PM »
Mine gets a little harder when I'm slowing and pulling into a parking lot - but not THAT much harder.
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« Reply #2 on: February 17, 2008, 07:05:43 PM »
Pressure regulating valve stuck? Make sure the lines aren't kinked. I'm thinking a power steering flush may help but you may need to replace the pump or gear which ever has the pressure regulating valve.(designed to give the same hydrolic force at low and high engine RPM)
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
Offline Chief
  • 678
« Reply #3 on: February 18, 2008, 04:10:11 AM »
That sounds like the problem. Lines are fine. Thanks
94tracker
« Reply #4 on: February 23, 2008, 06:47:34 PM »
Sounds like the same problems I'm having only left is worse than right. And I just installed it so fluid is new.
