tire sizes on ur rig
  • 45 Replies
  • 9996 Views
Offline whitfield
  • 633
  • 4-dr Kick on 34's
Re: tire sizes on ur rig
« Reply #15 on: October 19, 2004, 05:07:16 PM »
34" LTB's but working on 36's   I'm getting tired of all the mud falling out when i wrench on the Kick so I'm trying a little harder to avoid the big holes.  BUT once it gets dirty all bets are off.
with the 34's
Testing out a set of 36's
Offline safarikick
  • 270
  • nor-cal rhinos
    • http://www.cardomain.com/id/safarikick
« Reply #16 on: October 19, 2004, 06:07:12 PM »
that is the 2 BDS lift and a 3in body  with a 1.25 spring spacer in the front and the front strut mount was flip.  The spacer is tj. it sits on 31x10.50r15 Bfgoodrich A/T
3+3 calmini 5.12 a lock in the back and front with steel front diff. 4.24 in tc
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #17 on: October 19, 2004, 06:39:31 PM »
Im hoping my duel t case setup will arrive soon, but i run 33.12.50 mtrs.
Zig you probaby dont have this problem but i found last weekend they weren`t cleaning to well after hitting a mud run it was a clay base and not much water,  they were like racing slicks after 2 mins.
check out the tryes below
Maybe a set of simmex are teh way forward but i think i would kill my drive train.
Markyb (UK)
UK Vitara JLX SE
« Reply #18 on: October 19, 2004, 11:41:22 PM »
I have 33 x 9.5 BFGoodrich MTs on 7x15 rims. I run +2" suspension and 3" bodylift. I also have a steel front axle and 5:8s. Mainly used for non rocky trails and the occasional bout of mud plugging
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #19 on: October 19, 2004, 11:56:16 PM »
 :DI am running 36x12.50x15 swamper sx's on 15x8 10 hole aluminum rims.  Best tire I have found to date.  I have a Spring Over with wrangler springs fr and rr, 1" body lift, missing link (home made) fr and rr, Toy axles and lots of fender "massaging" with a 10 lb sledge.  I finally put bump stops in and it make a world of difference.  It's on a 1988.5 tin top Sami.  This size allows me to wheel almost everywhere.  I started in stock (!) form and have run the 31's, 33's, etc.  All good sizes with the proper driveline upgrades.  Good luck!
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
« Reply #20 on: October 19, 2004, 11:56:50 PM »
Why oh why wont it let me reply :'( This is my third try :'(
Poetry,
« Reply #21 on: October 20, 2004, 12:10:45 AM »
I'll try it again.
I dont ride in clay mud much, but I have found that MTR's will clean just about as good as other MT tires (not including TSL's and Boggers). But my favoriate part is with you go through a wet, mudy section and then hit rock, it just takes a little spinning ant the MTR's are heated back up and sticky enough to pull you over the rock ;D Not to mention they ride great on the road to.
After seeing how well the Krawlers hooked up on Mikes rig, I'll have to look into getting some of those when the MTR's wear out.
Offline supazuk
  • git 'er done!
« Reply #22 on: October 20, 2004, 01:13:12 AM »
i'm running 33X12.5X15 superswamper SSR's on 15x 8 rims  REAR:  with yj''s rear rancho 2" (TT)  on hybrid rear 4.5 perch  FRONT: was RRO rear up front and 6"RRO e-z weld ( bent springs and was racked forward with fender rubing) but going to  2" rancho CJ fronts  with m/l's and 5 " perches .. I don't want to have to put biger wheel spacers on.
ohh some BFH (big f'n hammer) liftin the fenders lol
shut up and wheel it.. sick of hearing oh my (fill in blank) stock can climb mountians yet the only off roading its seen is the curb their g/f ran over!
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #23 on: October 20, 2004, 02:54:22 PM »
31" interco trxus MT's, and old school 30" bias plys.. the trxus are a sweet ass tire so far, ill get pics asap
Sj410 Full exo, Locked, race buckets, 5 point
85.5 LWB sami, Toy axles, locked rear, CJ/RUF, warn 8000, 33's
Offline Bfunk
  • 406
« Reply #24 on: October 20, 2004, 04:39:09 PM »
I'm running 35x14.50 boggers on 15x8 wheels.  They will all be for sale soon.  I'm tired of running sissy little tires ;D
Brian
Offline waltc
  • 21
  • Bassuki with HID
« Reply #25 on: October 20, 2004, 04:39:54 PM »
I'm using my 'kick for commuting to work, taking my mountain bikes to trails and camping - probably no offroading.
I have 16's coming in. What tires should I get to fill the wheel wells?
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #26 on: October 20, 2004, 06:02:45 PM »
I just sold a set of Chrome 100 spokes with 205x55-16's   And yes they were off of a Kick.  I know I should have gotten a picture...    >:( :( ;D
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #27 on: October 21, 2004, 02:22:13 AM »
33x12.5's for now. Im aiming for 38's+
« Reply #28 on: October 21, 2004, 04:56:17 AM »
You might want to stay with the 8" rim if your going to run the 12.5" tires so you don't loose your bead so easily.
I run 33x12.5 BFG MTR's on a 15x8" wheel for standard trail runs.  They seem to get the job done, but I just siped them to see if I can get a little more flex without airing down further.  Usually I run around 8 psi on the trail and don't have any issues, will probably start switching down to 6 for rocks and snow.
Standard Spring Over lift, front fenders missing or trimed/hammered out.  Rear fenders cut.
Offline 1bigtracker
  • 3409
« Reply #29 on: October 21, 2004, 11:24:09 AM »
thats would be one big step,  not only do Krawlers only come in 35's and up but from what i hear they bite 10 times harder than a MTR
stu
  ÂÂÂÂÂÂÂ
