Throttle Postion Sensor trouble
  • 9 Replies
  • 2447 Views
Offline IrishBilly
  • 22
« on: March 18, 2008, 08:17:20 PM »
I receintly found out i had a bad tps sensor on my 1995 sidekick 16 valve 4 dr. I sucked it up and payed the $187.00 dollars  and installed a new one myself as per instructions in my chiltons manual. Upon installtion i reset the codes my remove both battery cables for several minutes and removing ecu fuse . I still have the same problem i still have next to nothing when it comes to throttle response i have replaced spark plugs ,wires, cap,roter, fuel and air filters and had injectors cleaned. What should i do next
Re: Throttle Postion Sensor trouble
« Reply #1 on: March 19, 2008, 09:05:05 AM »
Check the wiring, a friend had this problem and it was a broken wire from the TPS to the ECU. I bypassed the wire and it runs great.
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« Reply #2 on: March 19, 2008, 10:19:20 AM »
have you checked to see if you have enough fuel pressure at the injector's.  Mine is a 8v and had that problem kinda.  Come to find out the fuel pump was bad.
Offline IrishBilly
  • 22
« Reply #3 on: March 19, 2008, 04:13:57 PM »
Thanks man i will check that out this weekend
« Reply #4 on: March 19, 2008, 07:10:45 PM »
why do u believe the tps is the fault? Have u had the codes read? Sometimes auto parts stores will loan scanners. If u get real lucky ull get someone toview the tps voltage and diagnois the fault.
Offline BIG DOG
  • 105
« Reply #5 on: March 19, 2008, 07:36:01 PM »
You can read the codes yourself on a 95.
Some of the dumbest people I know seem to know everything.........Funny about that!
Offline IrishBilly
  • 22
« Reply #6 on: March 20, 2008, 07:15:53 AM »
i did check the codes myself  first it was 2 blink pause 1 blink then after the sensor it was 4 and 4
« Reply #7 on: March 21, 2008, 10:47:38 AM »
21 is TPS signal high
44 is Idle switch circuit open
Is it properly adjusted? if it is then you need to check the ground wire. The ground wire should be grey/yellow and goes to A24 on the ECU.
Offline IrishBilly
  • 22
« Reply #8 on: March 23, 2008, 08:34:26 AM »
ok i checked for loose wires and checked ground everything seems ok i rechecked codes now i have code 22 i alson re checked tps adjustment any suggestions
« Reply #9 on: March 23, 2008, 03:03:36 PM »
Code 22 = TPS signal voltage low. The opposite of what you had before, did you adjust the TPS again? Otherwise it sounds like you have bad connections.
