1.6L-2.0L
  • 29 Replies
  • 9243 Views
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
1.6L-2.0L
« on: September 21, 2004, 08:26:38 AM »
I have a 1994 Sunrunner GT and I was thinking of taking out the old 1.6L and puting in the new 2.0L that makes 155HP, or should I just turbo or supercharge the 1.6L. I just need some info to get my brain going :)
Sunrunner GT, Gold Trim Level
Re: 1.6L-2.0L
« Reply #1 on: September 21, 2004, 10:54:35 AM »
I like the Turbo mob myself  ;D
Offline Bfunk
  • 406
Re: 1.6L-2.0L
« Reply #2 on: September 21, 2004, 04:44:10 PM »
It's like your reading my mind.  The new Aerio has a 155 hp 152 lb/ft 2.3L.  A certain moderator told me that the 2.0L would bolt up to my automatic.  I hope the 2.3L would do the same.  With the gearing I'll have that's plenty of power, and I'll still have only the weight of an inline 4.  Me likey.
Brian
Offline Bfunk
  • 406
Re: 1.6L-2.0L
« Reply #3 on: September 21, 2004, 04:48:19 PM »
I just realized I'm excited about 155 horsepower!!!  Good lord I need help.
Brian
Re: 1.6L-2.0L
« Reply #4 on: September 21, 2004, 05:29:07 PM »
LOL, ya  I was/am excited about 155 HP too
You see 155 HP can propel me to 95 MPH in
the 1/4, and there are not too many street
car that do that, let alone a SideKick   ;D
Offline cj
  • 1276
  • I drive a really big ATV
Re: 1.6L-2.0L
« Reply #5 on: September 21, 2004, 06:53:36 PM »
Brian
As I understand it, the engine/transmission mounting points are the same but the depth of the bellhousing is different and the 2.0 runs a different crank so there will be issues with the torque converter and flex plate. Also, although the 2.0 was put into the Sidekick in OZ it had a wider chassis so custom engine mounts will be the order of the day. If anyone can confirm this it would be great as I am looking at this as an option.
Re: 1.6L-2.0L
« Reply #6 on: September 21, 2004, 10:33:46 PM »
Wilds goin gangsta ;D The Turbo Mob ;D
:PZig :P
Re: 1.6L-2.0L
« Reply #7 on: September 22, 2004, 02:33:12 AM »
Doh!!........  I just saw that  :-[
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
Re: 1.6L-2.0L
« Reply #8 on: September 22, 2004, 07:52:55 AM »
So what sould I do?? ???
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
Re: 1.6L-2.0L
« Reply #9 on: September 22, 2004, 08:03:44 AM »
Posted by: SunrunnerGT Posted on: Today at 13:52:55
It sounds like you need someone to just tell you what to do! :D
I say go for it man. Do you have the 2.0 right now, or would you have to buy one? I say if you have it, do it, plus you have some options: 1-swap would mean an extra 1.6 that you could throw in a sami 2- or you could sell the 1.6 to cover the expense of engine mounts for the 2.0 and whatever else you may need for it. If you don't have the 2.0, just hassle wild for all the details on his turbo and do that with your 1.6, I'm assuming it would be less costly...
steveo
Offline explosivo
  • 3157
Re: 1.6L-2.0L
« Reply #10 on: September 22, 2004, 08:06:22 AM »
Swap in the 2 litre, and turbo it! That's the only obvious solution! You could get like 175+hp! :o
omghi2.us[/url]
Online ebewley
  • 6601
  • 68
Re: 1.6L-2.0L
« Reply #11 on: September 22, 2004, 08:48:22 AM »
Are you thinking 2.0 V6? :) The 2.0 I4 will bolt to the 1.6 8-valve and 16 valve and 1.8 Sidekick transmissions with no mods. IF the 2.3 uses the same transmission goodies as the 2.0 it should be backwards compatible as well.
HTH -Eric
Offline explosivo
  • 3157
Re: 1.6L-2.0L
« Reply #12 on: September 22, 2004, 08:58:17 AM »
HTH -Eric
What about the motor mounts? Do they bolt up as well?
omghi2.us[/url]
Online ebewley
  • 6601
  • 68
Re: 1.6L-2.0L
« Reply #13 on: September 22, 2004, 10:09:07 AM »
No.  We're talking several different vehicles here. 1.8 from the Sidekick Sport and Esteem, 2.0 from the Vitara and the 2.0 & 2.3 From the Aerio. The Esteem and Aerio engines being transverse mounted.
FWIW, The 1.8 engine that I have bolted to a 1.6 8-valve 2WD transmission appears to have all the the same tapped holes for the engine mounts. Therefore, it might actually work in a Sidekick with the original Sidekick 1.6 engine mounts. Dunno..
Offline explosivo
  • 3157
Re: 1.6L-2.0L
« Reply #14 on: September 22, 2004, 10:24:14 AM »
Now for a stupid question: How do you go about putting motor mounts for a RWD/4x4 setup on an engine that came transeversley mounted from the factory?
omghi2.us[/url]
