Starter Not Engaging
  • 11 Replies
  • 5010 Views
Offline 87Sam87
  • 63
  • '87 Samurai JA and '86 Samurai JX
« on: May 05, 2008, 08:35:36 AM »
  When I try to start my Samurai the starter winds up and I can hear it spinning but it doesn't engage with the engine. Should I just replace the starter?
Thanks
Offline rascott
  • 669
  • 15
Re: Starter Not Engaging
« Reply #1 on: May 05, 2008, 10:04:34 AM »
sounds like the drive gear mechanism is screwed up.
i don't mess with them anymore and get a rebuilt from kragen auto parts(cause that's local + lifetime warranty).
i do that with alternators also, and have had pretty good service outa them.
i suspect you have a local parts place that does the same?
Offline 87Sam87
  • 63
« Reply #2 on: May 05, 2008, 03:19:42 PM »
   Yes I can get a lifetime exchange warranty from the local part store. I did test the solenoid and it's working so I think it's either the starter gear or the slip clutch.
   Does anybody have any tricks for getting the starter out of the Samurai? It's looking like that bolt on the top is going to be tough to get out.
Offline rascott
  • 669
  • 15
« Reply #3 on: May 05, 2008, 03:42:41 PM »
probably like my 1.3 kick-
the top bolt has a nut in back?
it was fun wiggling it out after unbolting. same with install.
Offline Amilla
  • 1076
« Reply #4 on: May 05, 2008, 05:46:29 PM »
I just pulled my starter out a week ago, and then just threw it back in.
That top bolt with a nut isn't to bad to get to but you defiantly have to wiggle your arm in there.  The bottom one is a piece of cake.
Don't forget the bracket that goes between the starter and the bell housing when your putting it back in.
Amilla
Offline rascott
  • 669
  • 15
« Reply #5 on: May 05, 2008, 07:08:17 PM »
is my kick supposed to have a bracket also?
(sorry to piggyback, but i just wondered)
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #6 on: May 05, 2008, 08:04:43 PM »
roll it then pop it in gear just to turn the flywheel a bit could be missing a tooth right where its sitting, also check the starter bolts mine used to come loose alot and grind teeth
Offline Amilla
  • 1076
« Reply #7 on: May 05, 2008, 10:34:11 PM »
Im not sure if kicks have the bracket too but on a sami, theres bracket that goes in there that holds 2 lines in place.
Mine was out when i pulled the starter, who ever did it before forgot to put i back in.
There were never any starter issues  caused by it not being there.
Amilla
Offline 87Sam87
  • 63
« Reply #8 on: May 06, 2008, 10:14:17 AM »
   I've pop started it a couple times and the problem keeps coming back so I guess I'm going to have to pull the starter.
   So you guys that have pulled the starter out, did you remove the heater hose above that top bolt? Did you just use a socket wrench on the bolt or what?
Thanks for all the help by the way, you guys are great!
Offline Amilla
  • 1076
« Reply #9 on: May 06, 2008, 02:10:30 PM »
I didn't pull any lines off, just worked my arms in around them.
Gear wrenches make life sooo much easier!
Amilla
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
« Reply #10 on: May 06, 2008, 04:23:19 PM »
   DITTO for gear wrenches!
KING ZOO!!
Offline 87Sam87
  • 63
« Reply #11 on: May 06, 2008, 09:49:50 PM »
   Gear wrenches, great idea!  I'd seen them but never bought any. I'll pick some up and give it a try.
