97 Sidekick
  • 2092 Views
97 Sidekick
« on: June 22, 2008, 01:32:13 PM »
Need Help!!! I have a 97 sidekick, 5 speed, 16 valve, cami lift, bracket broke loose from center of front dif, wallered out the housing from where the inner CV goes into.  Should I go back with stock aluminum housing with 31" tires no locker or I should I go ahead and use the 99 Vitara castiron housing?  Will I have to change out the ring a pinion or is it a direct bolt in?  I appreciate in any info, because I am knee deep in the ride.  How tough is that aluminum housing with 31" tires?
Thanks,
Goop
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
Re: 97 Sidekick
« Reply #1 on: June 22, 2008, 06:59:52 PM »
    The harder you drive the less likely the alumionum front diff will survive.I would go with the cast diff or mabey an Anvil from Calmini.
KING ZOO!!
Re: 97 Sidekick
« Reply #2 on: June 24, 2008, 02:59:55 AM »
Obviously not very if you've broken it. Get the steel one from a Vitra, or the one from Calmini
