90 8valve tracker transfercase question
  • 1789 Views
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« on: July 25, 2008, 08:43:11 AM »
does anyone have a diagram of the top of the transfer case.  I have no 4x4 indicator so i replaced with a brand new one plugged it in tested before screwing in and it work.  Screwed it in and nothing.  So i pulled it back out tested by hand still works but noticed when i shifted into 4wd that nothing is moving in the hole where the switch goes.  does anyone have any ideas or diagrams. ???
Re: 90 8valve tracker transfercase question
« Reply #1 on: July 25, 2008, 10:49:11 PM »
Not sure on the tracker but on the sammy it has a small metal ball under the sensor and the ball triggers the switch.  I assume the ball is raised mechanically by the internal linkage.  If the tracker is the same then maybe you are missing that ball.
Offline kubik1981
  • 232
« Reply #2 on: July 26, 2008, 06:04:25 AM »
yeah there is nothing down in there. Is there anyway to get the ball for that switch.  also what kinda fluid goes in the transfercase?
« Reply #3 on: July 26, 2008, 12:42:28 PM »
I just put 80/90 weight in the transfer case.  Works great for me.
As for the ball, I would give Hawk Suzuki a call if your in the states.
Offline kubik1981
  • 232
« Reply #4 on: July 26, 2008, 10:21:39 PM »
ok i will do that and thank you for the fluid type
