Toyota axles on my 02 tracker
  • 2922 Views
Offline YellowZR2
  • 59
« on: September 19, 2008, 12:00:51 PM »
I seen these on EBAY and was wondering if they could be used on my 02 tracker.
I'm assusming much much more would be needed but they could be a good start.
84 Toyota truck solid axles-EBAY
At $100 bucks and close enough to drive to easily it might be worth for me.
02 Tracker ZR2 2 door (mostly stock-BORING)
05 trailblazer LS stock and staying that way-it's our tow vehicle.
Offline Basher
  • 44
Re: Toyota axles on my 02 tracker
« Reply #1 on: September 19, 2008, 07:45:30 PM »
not sure on the tracker, i know guys run them on sammis, not sure how the t-case output sits on a tracker, on a sammi you need a passenger side pumkin in the front ,wich the toyotas have, the rear is also offset a little, some guys run the centered toyota pumkin and say it works fine... seems a little odd but hey whatever,also they are around 6-7 inches wider , great for alot of wheelin but maybe not what you want on the street
 and thats a really low price, im geussin they have gone up a bit, 84s are the most desirable becouse the housing truss runs all the way ender the spring perch on the long side, dont forget gears and lockers!
if you were right, dont you think i'd agree with you?
Offline Hillbillydave
  • 213
« Reply #2 on: September 19, 2008, 07:55:19 PM »
I would get them if I was close enough! ;)
Those axles should be very close to the width you need to fit your tracker. The tracker rear ends are centered. The front axle will have to be four-linked or leaf sprung. There are kits out there to do the swap, check out the sponsers of this site to find the kits.
Offline Amilla
  • 1076
« Reply #3 on: September 19, 2008, 08:09:59 PM »
Super good price front and rear!  And like Basher said the 84-85 front axles are the best to get.
If the price stays like it is, your getting one hell of a deal.
If you were to set it up with leaf springs you could do it pretty cheap and it wouldn't be to complicated.
Amilla
Offline MaD.72
  • 183
  • It's not what you buy, it's what you built!!!
« Reply #4 on: September 20, 2008, 10:11:23 AM »
Check this site, they got alot of information on those kind of swap...
http://bbs.zuwharrie.com/content/board,71.0.html
