Dead Samurai
  • 29 Replies
  • 6130 Views
Offline SNJSamurai
  • 386
Re: Dead Samurai
« Reply #15 on: October 30, 2008, 09:31:32 AM »
everyone keeps saying its an ecu. these guys know there stuff.  but it never hurts to make sure its not just an injector or a cut in the wiring. did u find any info on how to check the injectors
Bob
Offline idaholwb
  • 772
Re: Dead Samurai
« Reply #16 on: October 30, 2008, 02:30:37 PM »
 Been there done this many times. The dead spot is caused by a malfunctioning ECU due to corrosion and at least one bad capacitor. Yes it is throttle body injection. Replace the ECU and all will be right with your "Zukiworld" again.  8)
97 Sport
265/70-16s
2" lift
2.0 swap
Offline 1badzuk2
  • 89
    • my sammy more pics check it out
Re: Dead Samurai
« Reply #17 on: October 30, 2008, 04:00:26 PM »
yes thank you or like i said it can be rebiult if your not sure i can do it for you for a little bit and  you buy the parts or i can buy the parts and do it.  i have a 91 efi sammy not sure if the ecu is still in it illgo look and let u know
built sammy locked front an rear full roll cage 6 5 1 tc gears 96 16v motor and alot alot of mods
Offline SafetyGuy
  • 41
Re: Dead Samurai
« Reply #18 on: October 30, 2008, 06:01:35 PM »
I have the ECU out and pulled the cover off it. I am far from being a electronics expert or even know much about electronics, but it appears to me that resistors (I think that is what they are called) number C60, C106, and C112 are all leaking a black substance.
1badzuk2,
If you still have your ECU, please let me know.
If you Can Not Do It Safely, It's Not Worth Doing!
Offline SNJSamurai
  • 386
Re: Dead Samurai
« Reply #19 on: October 30, 2008, 08:23:38 PM »
im so glad i have a carb lol
Bob
Offline ROSS
  • 1412
Re: Dead Samurai
« Reply #20 on: October 30, 2008, 09:01:12 PM »
you know the carb ECU can do the same thing
Offline SNJSamurai
  • 386
Re: Dead Samurai
« Reply #21 on: October 30, 2008, 09:20:41 PM »
really how? what does it control?
Bob
Re: Dead Samurai
« Reply #22 on: October 31, 2008, 05:08:27 PM »
You can also use a fuse in the empty space in fuse box and the zuke will throw a flashing code via check engine light...
http://www.izook.com/tech/samurai/basics/basicdiagnostics/enginelight.htm
« Last Edit: October 31, 2008, 05:10:25 PM by zthatzmanz28 »
Re: Dead Samurai
« Reply #23 on: October 31, 2008, 08:12:52 PM »
I didn't see it suggested but on my 1.6 8v sidekick efi throttle body engine I was backing up and then it died out of nowhere.  After thinking the worst I found it was a fuse on the standard fuse block that handled the fuel injection.  I am not sure if the efi sammys have the same fuse but it would only take you a minute to look at all your fuses and make sure you have no blown ones.
Offline SafetyGuy
  • 41
Re: Dead Samurai
« Reply #24 on: November 02, 2008, 08:45:59 PM »
I found a injection system with the ECU for a 1.6L for sale for $150.00. Will this ECU work on a 1.3L engine?
Offline 1badzuk2
  • 89
Re: Dead Samurai
« Reply #25 on: November 02, 2008, 11:34:31 PM »
no but i did find that i have a 1.3 efi ecu from a 91 sammy id be intersted in a trade ill even give you a few bucks or is it on ebay if so ill still hook you up with the ecu cheap
Offline SafetyGuy
  • 41
Re: Dead Samurai
« Reply #26 on: November 03, 2008, 04:11:50 PM »
The ECU I found comes with the entire intake and wire harness. It is off a 1991 Tracker 1.6L EFI.
If the ECU will not work on my 1991 Samurai 1.3L EFI, can I put the entire 1.6L intake, harness, and ECU onto my 1.3L?
Offline idaholwb
  • 772
Re: Dead Samurai
« Reply #27 on: November 03, 2008, 10:15:41 PM »
 You would be better off just finding the correct ECU for your Sami.
 If you swapped the intake, throttle body, and ECU from the Trackick you would also need the distributor and housing. Not worth the hassle. And of course you have to redo the other harness.
 And no, you can't use the Trackick ECU. Totally different beast.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline 1badzuk2
  • 89
Re: Dead Samurai
« Reply #28 on: November 04, 2008, 12:07:59 AM »
no you cant use that on your 1.3 you will need a 1.6 motor    i have the ecu you need do you want to trade or can i buy the 1.6 intake and ecu and wire harness.?
Offline SafetyGuy
  • 41
Re: Dead Samurai
« Reply #29 on: November 04, 2008, 04:56:31 PM »
1badzuk2,
Yes, Please e-mail me at blessed_24_7|removethispart|@msn.com
Thank You
Paul
