1st samurai questions
  • 2386 Views
« on: November 27, 2008, 11:05:57 PM »
Picked up my Samurai tonight, only paid $1000 for it, not sure if that was too much.   Tin top JX model, has new 33x12.50 mud terrains on it, not sure exactly what kind of lift or how much but at least part if not all is shackles, has lockers front and rear, motor was rebuilt "recently," new bearings & seals in the rear, has been "geared down."  I've been big into dirtbikes up until know so kinda new to this seen.  I think I'm going to go try it out this weekend anything I should check over before I go?  Anyone in UT want to go up A.F. canyon or elsewhere close by saturday?
Re: 1st samurai questions
« Reply #1 on: November 27, 2008, 11:37:35 PM »
Sounds like a good deal to me.  Welcome to the sickness.  :)
Offline JayN
  • 220
« Reply #2 on: November 28, 2008, 12:30:31 PM »
sounds god, throw up some pics.
are they lockers or welded difs?
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
« Reply #3 on: November 29, 2008, 12:32:00 AM »
I'll try and get some pics up soon.  The front diff is welded & the rear has a locker in it. What is the difference? Sorry if its a dumb question.
Offline bbagwell
  • 278
« Reply #4 on: November 29, 2008, 01:50:10 AM »
A locker allows the tires to turn at different speeds as you turn a corner.  If the diff is welded the tires are turning at the same speed no matter what.
2002 Suzuki Grand Vitara
1983 Toyota PU
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: November 29, 2008, 06:14:34 AM »
One of the most common problems with Samurais is the shifter sheet in the transfer case.  If it is the original part, it is probably worn out.  Do a search for shifter sheet here for more information.  A very reliable replacement brass shifter sheet is available for less than $25.00 from Zuks Offroad (http://www.zuksoffroad.net/).  If you can't wait for the sheet, be sure to carry a couple of long handled flat-bladed screwdrivers with you on the trail.  Take a look at this webpage to learn what you need to do if the t-case does "lock up" before you go: http://forum.difflock.com/viewtopic.php?t=2285&highlight=.  You can find this and other helpful links at Ack's FAQ (see link in my signature).
If your Samurai is a "Daily Driver", you'll probably notice some bad (but very fixable!) steering/handling habits if the PO was not careful when modding the suspension.  There is lots of information on "bump steer", "death shakes" and more at zukiworld.com and other great Zukin' websites!
Ack
