throw out bearing keeps gettin thrown!!
  • 2362 Views
« on: December 28, 2008, 07:16:54 AM »
i was wondering if anyone had this problem and if so how they fixed it if you even can.
i have a 94 4 door sidekick.every 3 months or so my throw out bearing gets thrown off the clutch for its beggining to be a pain in the ass because i have to drop the tranny and i replace the throw out bearing everytime i do this does anyone have any idea what can cause this.lmk if anyone has any ideas
mod list: if it helps
engine: miles 225k
custom turbo set up |removethispart|@ 4-6psi( .50 trim turbonetics turbo,custom manifold)
stock internals
eclipse side mount intercooler
custom piping
hacked maf
apexi safc
boost controller
3in exhaust
turbo muffler
not cat
driveline
stock replacement clutch kit
stock gears
stock driveshafts
driveshaft spacers (lowrange offroad)
suspension
f150 4x4 springs
2in coil spacers
ome struts w/spacers
rancho shocks (4 runner 6 in lift)
3in body lift
no sway bar
im running 33x13.5x15 swampers w/1.5 in wheel spacers
Offline ROSS
  • 1412
Re: throw out bearing keeps gettin thrown!!
« Reply #1 on: December 28, 2008, 07:34:16 AM »
sounds like someone is riding the clutch
« Reply #2 on: December 28, 2008, 09:34:40 AM »
why would the bearing grt thrown off the fork by riding it? when i pull the tranny it falls out as soon as the trans is seperated.i understand that riding the clutch would make the bearing go bad but not fall off
« Reply #3 on: December 28, 2008, 12:22:47 PM »
Check the clutch fork to make sure that its not bent.
Offline ranger88den
  • 279
« Reply #4 on: December 29, 2008, 05:56:43 AM »
As Rhinoman said, check the fork.
good luck
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #5 on: December 29, 2008, 02:23:40 PM »
Maby the fork is worn?
or
Have you ever had the resurfaced?  If too much material was removed, maby this could cause the fork to over travel and cause the bearing to pop out?  Just a thought.
Good luck
32 MTR's Warn 8000i
« Reply #6 on: December 29, 2008, 03:25:14 PM »
i pulled my trans today and its the fork its mangled now you cant even put a throw out bearing on it just falls right off thanks for all your help
« Reply #7 on: December 30, 2008, 09:34:39 AM »
I would love to see some pics under your hood. Me <3 Turbo 16V
