TracKick Trailer Conversion
  • 2513 Views
« on: December 30, 2008, 02:55:52 PM »
I love Samurais, but I've recently been sticking to Kicks because they have more cargo space. I've got a 4-door Sidekick I'm parting out, and I'm thinking of cutting off the front between the doors, and converting it into a trailer. The front part of the frame could be cut & shaped to become the tongue & mini-storage area. The rear gas tank can either become a "Jerry Can" holding 12 extra gallons, or converted to a water tank (would have to line it with something to prevent rust, or replace it with a plastic tank) for running potable water  8) If I extended the front out a little (foot or two) I could throw in an air mattress & sleep in it too! If I put in the 16V 4-speed in the Samurai, would it have enough power & weight to tow it safely?
Pic's worth a 1000 words. Vertical line is about where I'd cut it, and the horizontal is where I'm guessing the frame is, and the tongue would be:
Offline ROSS
  • 1412
Re: TracKick Trailer Conversion
« Reply #1 on: December 30, 2008, 04:33:07 PM »
i'd cut it right in front of the front doors. give it a nice shape.
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #2 on: December 30, 2008, 05:35:15 PM »
Offline rockyzuk
  • 10
« Reply #3 on: December 30, 2008, 06:28:13 PM »
that camper idea is bad ass!!
« Reply #4 on: December 30, 2008, 06:30:38 PM »
I would like to have enough room to sleep in it, but I'm a little worried about making sure i keep good weight distribution. Especially if I'm pulling behind a little Samurai  :'(
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
« Reply #5 on: December 30, 2008, 08:45:17 PM »
Done some stuff like this before, Jeremiah, and I think your proposed cuts look good. Unlike the other post, I'd do whatever I could to keep the center of gravity low, water/fuel ballast is a good idea. Check on the % "forward of center" to determine a good tongue weight compatible w/your tow rig. Putting an aerodynamic "nose" up front should give you some foot room too. Post a build-up I can't wait to see some welds! Good luck!
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
Offline Swansen
  • 64
« Reply #6 on: December 31, 2008, 06:45:34 AM »
make it into a pickup  ;D
