Samurai Question?
  • 9 Replies
  • 2375 Views
Offline Asbury030
  • 85
Samurai Question?
« on: January 01, 2009, 01:41:57 PM »
Ok so I want to take the body off the frame of my samurai. I was just wondering what all I have to do to get this accomplished?
Offline Armour
  • 360
Re: Samurai Question?
« Reply #1 on: January 01, 2009, 04:34:43 PM »
Unbolt it! LOL! I am such a smartass!
Offline Asbury030
  • 85
« Reply #2 on: January 01, 2009, 04:45:26 PM »
haha I know that. Like do I have to take the motor out and the dash and how many bolts are there and where at? Im new to this as you can tell. What I wanna do is sand down the frame repaint it and put bed liner on it.
Offline Asbury030
  • 85
« Reply #3 on: January 02, 2009, 03:34:21 PM »
Anyone?
« Reply #4 on: January 02, 2009, 03:41:01 PM »
I believe the FSM covers it.
You have to pull the electrical running from the engine into the dash, the shifter, clutch and speedo cable need to be disconnected, and the emergency brake.  Radiator will have to be pulled along with where the steering box connects (the rag joint).  Then just unbolt everything like on a body lift.
I would just start lifting it up slowly at that point and see what you missed.  :)
« Last Edit: January 02, 2009, 04:45:46 PM by Drone637 »
Offline Asbury030
  • 85
« Reply #5 on: January 02, 2009, 04:19:14 PM »
Ok cool thanks I appreciate it.
Offline Asbury030
  • 85
« Reply #6 on: January 03, 2009, 08:41:53 AM »
How many bolts are there holding the body to the frame?
Offline ROSS
  • 1412
« Reply #7 on: January 03, 2009, 05:58:16 PM »
10 I believe
Offline idaholwb
  • 772
« Reply #8 on: January 03, 2009, 06:06:56 PM »
 Don't forget the brakelines where they attach to the fenderwell...
97 Sport
265/70-16s
2" lift
2.0 swap
Offline ROSS
  • 1412
« Reply #9 on: January 03, 2009, 08:12:57 PM »
note "the body to the frame"..   theres quite a few little things like vent hose to cannisterground wires fuel filler hose  but, he said bolts to frame
