fuel injector interchange
  • 11 Replies
  • 4149 Views
Offline pidder
  • 61
  • 88.5 samurai, homemade bumpers, rock sliders,spoa
« on: January 20, 2009, 08:11:18 PM »
Does anyone know if there is another Suzuki product you can use the fuel injector from to put into a 89 tracker?  The auto wreckers here never seem to have trackers or sidekicks but have a few firefly's, swifts etc.  Would the fuel injector be the same in one of these applications?  Or maybe the whole throttle body.  Thanks
« Last Edit: January 20, 2009, 08:12:55 PM by cj2a »
Offline pidder
  • 61
Re: fuel injector interchange
« Reply #1 on: January 22, 2009, 04:20:43 PM »
Nobody has an answer for this one?   Nobody?
« Reply #2 on: January 23, 2009, 04:36:33 AM »
I'm not aware of any other injector that will interchange.
« Reply #3 on: January 23, 2009, 08:40:45 AM »
Did they have Swifts available with the 1.3 in 89?
« Reply #4 on: January 23, 2009, 01:29:04 PM »
The best question is why do you need/want another injector???
Do you have a no start SideKick??? Might be the computer
Good Luck
Offline pidder
  • 61
« Reply #5 on: January 23, 2009, 10:44:28 PM »
No not the computer.  My buddy had starting problems and tried testing everything.  After changing the fuel injector width one I had in a motor slated  to go into my samurai, his starts fine.  So need to find a new injector for him so I can get mine back.  I Believe the dealer told him something like five hundred bucks for an injector.  Lordco was over three hundred.  I just thought if something else would work from the wreckers it would be much cheaper.  thanks.
« Reply #6 on: January 24, 2009, 09:13:41 AM »
You can get used Injectors from Hawk Suzuki, I bought a couple for a 16v at a decent price.  Not sure about an 89 1.3 though.
Offline pidder
  • 61
« Reply #7 on: January 24, 2009, 05:57:33 PM »
The injector I need is for a 1.6 tracker motor not a 1.3, sorry for the confusion.
« Reply #8 on: January 24, 2009, 07:47:18 PM »
Samurai fuel injectors will interchange, but I'd bet EFI samurais are more rare than the trackers and sidekicks in the yards.
« Reply #9 on: January 24, 2009, 08:27:14 PM »
Go to pirate4x4.com and start looking up "turbo" in the suzuki threads. I could have sworn there was someone using Nissan injectors to keep up with the boost in his 1.6L
« Reply #10 on: January 24, 2009, 08:57:35 PM »
Probably the reason they are using different injector(s) is that the Nissan injectors have a higher flow rate that stock trackick injectors.  I would guess if you use a higher flow injector in a stock engine, then it would run rich.
« Reply #11 on: January 25, 2009, 05:55:07 AM »
There are alternatives for the high impedance injectors fitted to the 16V MPI engines. However the 89 is a TBI. I can't see a search button on the Pirate forum, possibly because I'm not registered.
