Running lockers in the midwest environment ?
  • 2263 Views
Offline RazBarlow
  • 156
  • It's Barney !
« on: January 31, 2009, 04:18:53 PM »
I live in Iowa and we have all kinds of weather, snow,Ice,heat,rain you know the bit. I was just wondering if the people that have the same environment run lockers on their DD ? If so, what type/brand are good and where do you get them ?
Thanks,
Raz
Offline RazBarlow
  • 156
  • It's Barney !
Re: Running lockers in the midwest environment ?
« Reply #1 on: January 31, 2009, 04:20:24 PM »
I forgot to mention, this would be pertaining to a 1994 2 door tracker.
Raz
« Reply #2 on: January 31, 2009, 04:57:50 PM »
I ran a lock right in my 89 sidekick I use to have.  Worked fine, but took some getting use to, driving with it on the road (which was no surprise).
Offline RazBarlow
  • 156
  • It's Barney !
« Reply #3 on: January 31, 2009, 05:02:10 PM »
For on/offroad use you only want to run a rear locker, not a front locker correct ?
Thanks,
Raz
« Reply #4 on: January 31, 2009, 05:11:55 PM »
Thanks,
Raz
You could run a front locker.  Unless you have it in 4wd, you will not even know it's there.
Offline RazBarlow
  • 156
  • It's Barney !
« Reply #5 on: January 31, 2009, 05:20:02 PM »
Does anyone have a sticky on the locker installation and where is a good place to get one ?
Raz
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
« Reply #6 on: January 31, 2009, 10:37:47 PM »
I put a steel diff in the front with a locker, in the rear I'm gonna do a spool. I've driven welded rears on the street and found it manageable. As far as the locker in the front, I think mines a "Detroit" or "Eaton", I don't remember, they're the same. I would'nt wheel seriosly without it. Lock the hubs and you loose turning radius, engage 4WD and turns get real tough.  In the woods I engage and disengage constantly getting around trees, with the rear spooled I'll do this less.
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #7 on: February 01, 2009, 10:48:44 AM »
well I run a rear mini spool in my 94 tracker in minnesota, I do alot of daily driving with it on the road, highway, town.  Love it I like it better in the winter than stock.  AS for turning since a spool keeps it locked up all the time I just turn alittle wider, unless I have to turn tight.
I would do mini spool again in a heartbeat, I am parting out my tracker now and the spool will be going into my samurai.
Offline RazBarlow
  • 156
  • It's Barney !
« Reply #8 on: February 01, 2009, 03:48:19 PM »
Who sells mini spools and lockers and which is less $ ?
Raz
