HOT A/C !
  • 15 Replies
  • 4339 Views
Offline jerryp58
  • 449
HOT A/C !
« on: August 29, 2004, 09:59:32 AM »
Yesterday the A/C was fine, today, hot air :-/
Guess I'll be doing the R12 to R134 conversion earlier than I had planned.
Jerry
Re: HOT A/C !
« Reply #1 on: August 29, 2004, 11:44:41 AM »
Did ya check to see if the A/C clutch is still working?
Temp control set to cool?
Don't laugh, it happens.
Went wheeling yesterday, when we finished I wiped all the dust off my dash and such. On the drive home I couldn't figure why it was soo hot in the Tracker. Silly me, I bumped the temp and it was on high :o
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
Re: HOT A/C !
« Reply #2 on: August 29, 2004, 05:29:52 PM »
Yeah, I just figured out that my A/C doesn't work too.  What could be the problem?
Re: HOT A/C !
« Reply #3 on: August 29, 2004, 05:52:25 PM »
Make sure the bolts that hold the compressor to the bracket have not come loose. The belt will slip and the compressor will not run. In most applications, you will also loose your power steering.
Tony
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
Re: HOT A/C !
« Reply #4 on: August 29, 2004, 07:50:47 PM »
Takes me about 15minutes to get my A/C to come on. Sometimes its faster to get the top off with 2 people... ;D
Offline jerryp58
  • 449
Re: HOT A/C !
« Reply #5 on: August 29, 2004, 10:36:51 PM »
It started raining so I didn't go out there and check under the hood yet.  Maybe I'll get lucky and it'll be something simple.
I did have all of the buttons/slide-controls where they needed to be, and my A/C usually throws cool air within 15 seconds, I waited 5 minutes and still hot air.
Jerry
Offline jerryp58
  • 449
Re: HOT A/C !
« Reply #6 on: August 29, 2004, 10:39:25 PM »
Tony
No power steering to lose, but I'll definitely check the bolts when I go out there this morning.  I had another car whose alternator bracket bolt would back out and twice it was sheared off at the block (PITB to get the remaining bolt out of the block >:( ) so I don't want that happening here.  Thanks.
Jerry
Offline 1bigtracker
  • 3409
Re: HOT A/C !
« Reply #7 on: August 30, 2004, 05:39:28 AM »
you guys are worryed about you A/C working, i'm trying to set mine up to have onboard air. ;D
stu
Offline jerryp58
  • 449
Re: HOT A/C !
« Reply #8 on: August 30, 2004, 09:56:24 AM »
stu
Unless it's around 100*, A/C is usually open windows, but when the spouse is in the car, it's A/C all the way.
BTW, I gave a quick look this morning and the bracket & compressor were secure, belt was on, and no obvious hose damage.
When this monsoon stops, I'll check the inline fuse, but I noticed that the site glass was dark (instead of green, I believe).
Jerry
Offline keith
  • 1176
Re: HOT A/C !
« Reply #9 on: August 30, 2004, 01:45:26 PM »
What' this A/C you are talking about?  Do you mean taking the top off and driving faster?  ;D  My Galant has a setting where cool air comes out of the dash, but that's a car with all sorts of comfort bells and whistles.  I didn't think 4X4's came with such an option.  ;)
Re: HOT A/C !
« Reply #10 on: August 30, 2004, 02:37:28 PM »
I gave mine to a friend.  It'll rob what HP you got.  ;D
Unless you have a K&N aircleaner and a NOS sticker to make up for it ;)
« Last Edit: August 30, 2004, 02:41:03 PM by trickker »
Offline zukiboy
  • 42
  • Wheel Forever !!!
Re: HOT A/C !
« Reply #11 on: August 30, 2004, 03:47:25 PM »
Find your high limit switch,usually near the firewall or heater core area and has 2 wires. with everything turned on like it should work take a paper clip or jumper wie and jumper between the 2 with the plug still attached and check to see if the compressor comes on, if it does you lost your R-12 somewhere. If it doesn't a fuse or wire is off somewhere like on the compressor itself would be a good place to start. Good Luck
88 sami
3"lift 30's
No matter where you are there you'll be
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: HOT A/C !
« Reply #12 on: August 30, 2004, 03:54:52 PM »
Oh man, I love my A/C! Nothing's nicer than jumping out of the Zuk at the end of the trail cool and clean when everybody else is dusty and sweaty. But I am gettin' old and I need my creature comforts. :)
« Last Edit: August 30, 2004, 03:55:41 PM by TN_Tracker »
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
Re: HOT A/C !
« Reply #13 on: August 30, 2004, 06:21:52 PM »
Yeah, what's with that? Everytime I put on the A/C, my car feels sluggish. I like it for long trips, but it is an actual noticable difference in performance when I turn it on! What a waste... So how do you go about "giving it to a friend?" I'd get rid of it in a flash to permanently free up that hp!
steveo
Offline 90Stomper
  • 427
Re: HOT A/C !
« Reply #14 on: August 31, 2004, 10:45:46 AM »
its that stuff in that box under the work bench.  o, thats me..... pitch it all my man, less drag, less weight, all ya need is a shorter belt and a cooler with ice in the back. 8)
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
but its covered with lots of big 'S's on the inside ;)
