96 Tracker passenger axle?
  • 2482 Views
Offline trevorsride
  • 85
  • Coos Bay Oregon
« on: February 20, 2009, 07:18:56 PM »
What holds it in? Im in the middle of lifting my rig, and had to pull the passenger front axle. When I put it back in, it just kinda slid in by hand with a little push. When I pulled it, it came out really easy too. Is this normal?
96 Geo Tracker 1.6 16V 3spd auto 2 dr soft top Jeffs 2" spacers, and 30" tires
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
Re: 96 Tracker passenger axle?
« Reply #1 on: February 20, 2009, 07:35:01 PM »
It's held in with a spring clip ring on the end of the shaft. Make sure it's on the replacement
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
Offline trevorsride
  • 85
  • Coos Bay Oregon
« Reply #2 on: February 20, 2009, 07:45:09 PM »
I didnt even pull it all the way out of the axle tube, so I didnt see it. Im just putting a 2" coil spacer in, and slid it out enough to get the spring back in. Just wondering how easy they go back in? Mine seemed really easy to pop back in by hand.
  • 169
« Reply #3 on: February 20, 2009, 07:48:10 PM »
You should feel it at least "click" in. Sometimes harder or softer, but you should feel sumthin'! ???
Offline trevorsride
  • 85
  • Coos Bay Oregon
« Reply #4 on: February 20, 2009, 08:22:44 PM »
There was a slight thunk as I pushed it the last 1/4 inch, but it was a light thunk? Do you usually have to hit them with a rubber hammer or anything, or is it really that easy?
Offline ToyYoda
  • 226
« Reply #5 on: February 20, 2009, 08:57:25 PM »
Yes it's that eazy. Now taking it out should be much harder. In most cases you need to place a pry bar or large screw driver between the axle end & diff. to pop it out. If it pulls out eazy check the "C" clip on the axle end & poss. spread out the clip or get one slightly larger. After you install your new spring spacer the axle will want to pop out when front end drops out more so than the stock set-up. ( like hill climbs) Spending time now will save you a trail breakdown,
Offline trevorsride
  • 85
  • Coos Bay Oregon
« Reply #6 on: February 20, 2009, 10:26:41 PM »
Ok, well I went back out, and yanked on it, and I cant pull it out by hand. When I removed it, I used a claw hammer, and it poped right out. Im assuming it is where its suposed to be, or I would be able to pull it out by hand?
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #7 on: February 21, 2009, 07:17:20 AM »
yep doesnt seem like alot but it works huh... lol
Offline 90camozuki
  • 90
  • Go Hard or Go Home!!
« Reply #8 on: February 21, 2009, 05:18:58 PM »
I did the same thing when i put my spacer lift on last week. I have since drove about 250 miles. no problems here.   :P
1997 Jeep Cherokee 2" lift,  31s, snorkel, arb bumper, roof rack, piaa lights, soon to be 4.5" super flex lift.
1973 Dodge Charger, fully restored, banana yellow...
2001 Dodge Ram 2500...work truck...
2006 Honda Pilot...wifes ride...
1998 Pontiac Grand Prix GT....Gas saver.......
