Samurai rear brake proportioning valve
  • 5114 Views
Offline cstello
  • 33
« on: February 26, 2009, 01:44:34 PM »
My rear proportioning valve is leaking. Where can I get a new one that doesn't cost me an arm and a leg?
Re: Samurai rear brake proportioning valve
« Reply #1 on: February 26, 2009, 07:26:44 PM »
Try Hawks or just bypass it and get one from spidertrax.
Offline Dimitros
  • 75
« Reply #2 on: February 26, 2009, 10:47:51 PM »
Same thing... It seems my rear wheels don't brake enough. What if I connect rear brake line directly, bypassing the proportion valve?
Curious, what might happens when I'll brake on snow/ice or any slopy road?
95 Samurai, 1.3, high comp.pistons, ported/grinded head, 1.6 valves, bored intake, Solex carb, K&N air, MSD Coil-Blaster+MSD 8.5 wires+Denso Iridium IW16 plugs, Calmini Tri-Y heder, Cherry-Bomb+Bosal custom exhaust, GRS II 4.89 T-case, 3.92:1 R&Ps, Calmini 3.5" susp., 30" BFG ATs, AVM 538 hubs...
« Reply #3 on: February 26, 2009, 11:43:07 PM »
The rear end of the rig will pass the front of the rig!
Offline Dimitros
  • 75
« Reply #4 on: February 26, 2009, 11:50:14 PM »
Is it mean that better to replace it with new one? Is Spidertrax any difference of stock one?
« Reply #5 on: February 27, 2009, 08:27:18 AM »
I believe the Spidertrax one is adjustable, so you can tweak it to work best with your particular configuration.  If you need a little more rear brakes you can just dial it up.
Offline TrakJD
  • 232
« Reply #6 on: February 27, 2009, 10:38:20 AM »
When my rear driveline snapped at ujoint the female yoke smashed the brake porportioning valve.  I ordered one from Trail Tough for $45, yes I couldve went with spidertrax.... but I didnt want to yet.
