New Toy SAS kick from Québec!
  • 26 Replies
  • 6390 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: New Toy SAS kick from Québec!
« Reply #1 on: August 24, 2004, 02:40:48 PM »
Looks good man fellow canadian
We should hit the trails some time
01 GRAND VITARA
Offline szabotage
  • 114
  • snaggletooth
« Reply #2 on: August 24, 2004, 02:46:14 PM »
sweet truck, good to see he finally finished the project! or at least nearing  the completion of ;D
« Last Edit: August 24, 2004, 02:46:33 PM by szabotage »
Offline 1bigtracker
  • 3409
« Reply #3 on: August 24, 2004, 02:56:22 PM »
you know, from when i started building my tracker i have always thought it owuld be one of the badest and i have thought that for a long time, but the more SAS trackers with 2 cases and lockers front and rear makes me think how far behind i am to be one of the best.  dose anyone know this guy?  i would really like to talk to him online.
stu
Offline szabotage
  • 114
  • snaggletooth
« Reply #4 on: August 24, 2004, 03:04:41 PM »
I know of him and what he's done, his names Xfaktor he frequents  zookpower.ca , team swift, pirate, offroad.com, but not sure if he's been around here.
he definitely knows his zuks, last years suzican he was running a 1.6 twin cam frankenstein motor in his samurai on 31's, that was a real screamer!
« Reply #5 on: August 24, 2004, 03:17:51 PM »
stu
I know how you feel.  :-/
Offline 1bigtracker
  • 3409
« Reply #6 on: August 24, 2004, 03:44:40 PM »
did he buy his t-case gears from a vendor or build them???  i would like more info on how he put his cases togather and the twin sticks.
stu
Offline szabotage
  • 114
  • snaggletooth
« Reply #7 on: August 24, 2004, 04:22:32 PM »
I have the exact same t'case setup in my rig and it's all home fabbed, I believe he did his rock lobster and twin stick himself, the build up shows all from what I see in his website
the only thing I didn't do to the dual t'cases was TIG welding plates to the kick case after cutting off the front driveshaft output. cost- $60 bucks Can.
the only differences betwwen my setup and Xfaktor's is my intermediate shaft, mine is just a shortened kick driveshaft, X connected the 2 flanges together with a single Ujoint and built a frame to connect the sammi case to the kick case as one unit, basically a ghettoed OTTkicker3
« Last Edit: August 24, 2004, 04:24:44 PM by szabotage »
Offline 1bigtracker
  • 3409
« Reply #8 on: August 24, 2004, 04:34:27 PM »
ahh thank you, i think the 4 door parts truck just became the new rock rig.
stu
Offline snakeman
  • 274
  • Alrighty Then
    • Oregon Trail 4x4 Association
« Reply #9 on: August 24, 2004, 04:41:18 PM »
Last I heard, Sky was working on a kick/samurai t-case adapter/ dual case setup of some kind.. Might e-mail him and ask how its coming.
Jeff
Oregon Trail 4x4 Association - Eugene, Oregon
http://www.ot4x4.org/[/url] Come check us out if your in the Eugene / Springfield area!
87 Tin Top, 1.6 16v, 4.9, 4.62's w/ sidekick rear, TT YJ swap, custom snorkle.
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #10 on: August 24, 2004, 05:13:47 PM »
stu
;) :o 8) ;)   :) :)    8) 8) 8)   Welcome to the Darker side.
I've got the F-150 coils, TT's Mighty Kong, and an extra sammy case and D-shafts ready to fab.   But then I ran across two screamin deals, a 1995 2dr Conv Kick, and a 1998 2dr Conv Kick.  Now I've got some more (Non 4-door) work to do.
« Last Edit: August 24, 2004, 05:17:25 PM by whitfield »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #11 on: August 25, 2004, 02:54:43 AM »
ugh those toy truck axles look narrow. :P
I believe the axles are about 5-6 inches narrower than a sidekick axle. Can somebody maybe correct me on this? How exactly do the toy pickup truck axles fit and feel under a track kick? I've seen Glenns, and I guess it doesn't look bad..  If I were to do toy axles (which I may do in the future) I think the axles I'd need to be looking at are from a toy landcruiser 60 series:
Lots of rust too, so why not make it a trail rig lol.
74.3:1 final drive? Wow. Mine is 179:1.  ;D
I'd like to see some pictures of that truck outside of the garage.  Good job though. It's always neat to see someone take on the SAS project.
Heather
« Last Edit: August 25, 2004, 03:11:40 AM by hcgalvin »
Heather Galvin
Offline 1bigtracker
  • 3409
« Reply #12 on: August 25, 2004, 05:46:58 AM »
here found this at another fourm, thought it might help.
Axle info - Toyota
Stock Toyota front axle measurements for comparison:
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners
63.5" wide, (set up for coil springs) 90-97 FJ80 and FZJ80 Landcruisers
'86-95 IFS front end is about 58.5" wide
'93-98 T100 IFS front end is about 65" wide
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-up Tacomas/4runners
66.75" wide, '93-98 T100 trucks
stu
Offline CanadianZook
  • Always towin the Toyotas !!
« Reply #13 on: August 25, 2004, 12:35:09 PM »
Wow, not bad. Have a look at mine. I have installed a D44 front and Ford9" from a 66' Bronco with Spools and 5.83 gears. I also run 35" MudRover tires from Dunlop and a Twin stick convert to go 2WD low.
What do you think ??? ;D
« Last Edit: August 25, 2004, 12:36:34 PM by CanadianZook »
92' Kicker, D44F, Ford9",Spools,5.83 gears, MMarker Winch, 35" MudRovers
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #14 on: August 25, 2004, 01:32:52 PM »
The page cannot be displayed
