Who all has Coil sprung Sammie?
  • 15 Replies
  • 3981 Views
« on: August 26, 2004, 04:32:18 PM »
I have a Plan for a SAS Tracker but need info on Sammie Sprung kits. The only one I've found is RROs.
And thats my Plan ;D
Offline 1bigtracker
  • 3409
Re: Who all has Coil sprung Sammie?
« Reply #1 on: August 26, 2004, 04:35:03 PM »
i think you should just round up every pic you can get of it and copy it.  i know NC_ZUK just did a yota convo on his and has TONS of pics.
stu
« Reply #2 on: August 26, 2004, 04:41:17 PM »
My plan (as for I'm no Fabracater) is Maybe buy a Kit for a Sammie and convert it for Tracker usage.
Being if I bought 16 Heim Joints, I hear they run around 50 bucks each :o = 800 bucks.
Coil kits ran 1200 bucks.
Sell old lift and such. 1500 bucks back (in Theory)
(ARB Lockers, gears, lift, GV axle. and what not)
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #3 on: August 26, 2004, 04:45:25 PM »
i contacted calmini about that and the tech guy said it would be more cost efeective to build my own, because it would have to be modified so much. the frames are very differnt in size and wieght.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
http://www.geocities.com/race8thwonder01/ http://www.cardomain.com/memberpage/769479
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #4 on: August 26, 2004, 05:31:05 PM »
There full of shnit. I had the same idea awhile back but never realy checked into it But cant imagin to much difference.
As we moving with the speed of the robot sonic exhaust
Chronic fumes, fuel, gin, and tonic
Half of the world is corrupt and alive
The other half is depressed and they want to die
« Reply #5 on: August 26, 2004, 06:17:33 PM »
There full of shnit. I had the same idea awhile back but never really checked into it But cant imagin to much difference.
My thoughts Exactlly. I was just informed by Idaholwb
That TrialTough may already be thinking this along this way
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Can happy days be just around the corner?
« Last Edit: August 26, 2004, 06:18:44 PM by trickker »
Offline explosivo
  • 3157
« Reply #6 on: August 26, 2004, 06:27:22 PM »
This thought also occurred to me (or was suggested by another Zukiworld-er :P, hard to seperate the two sometimes ;D), but I figure that the RRO kit has bushings and not heims, it'd be cheaper (and more fun/interesting) for me to fabricate something on my own, but use NC_ZUK and other coil-sprung sammy pics as a guide :)
omghi2.us[/url]
« Reply #7 on: August 26, 2004, 06:34:18 PM »
I like the Idea of Hiem joints for more flex, longer life and adjustablity.
But I'll see what TraiTough has to hopefully offer. They may need a tester ;D
See ya all tomorrow nite.
« Reply #8 on: August 26, 2004, 06:37:50 PM »
There are some industrial supply houses
out here, I wonder if their Heim Joints are
a lot less expensive than 50 bones each
Offline explosivo
  • 3157
« Reply #9 on: August 26, 2004, 06:46:16 PM »
I was looking around at some of the parts that my dad had laying around for our tractor's 3-point hitch, and the ends look just like (are) heim joints, and I know for sure that they aren't 50 bones a piece... but I still will probably go for bushings in mine since I don't need super amounts of flex and will probably take mine apart on multiple occasions anyway ;D
omghi2.us[/url]
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #10 on: August 26, 2004, 11:59:30 PM »
Ok, my turn! ;D I think that the RRO kit or Shaffers off-road coil kit could be modded for a kick. The most difficult part (not really difficult) would be fabbing resting points for the front coils. Sounds very tempting!!
Heims vs Johnny joints. The bushings you guys are reffering to on the RRO kit aren't just rubber bushings. They are Johnny Joints. These are rebuildable joints that really flex/move well.I like them a lot and trust me, they cost a good bit more than a rod end. My thoughts are this. If you are gonna run your rig on the road the bushings are the way to go as they will soak up some of the axle/tire/road vibrations whereas the rod ends are metal and will transfer the vibes into the body it self due to metal on metal contact
just my .02 ;)
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline bandit86
  • 1641
  • elv8rguy
« Reply #11 on: August 27, 2004, 12:47:36 AM »
if you're selling that locker, pm me
« Reply #12 on: August 27, 2004, 01:42:54 AM »
Well there you are Mr  NC_ZUK
Just thinking about your rig. wheres this "Shaffers off-road coil kit"?  I've Em'ed  RRO about their kit and checked the possiblity of it being adapted to a Kick.
I'm not in a really big hurry but the sooner the better ;D
Is your site working Okay?
« Last Edit: August 27, 2004, 01:47:08 AM by trickker »
Offline nc_zuk
  • 406
    • www.samurai4x.com
« Reply #13 on: August 27, 2004, 03:46:55 AM »
Shaffers is actually the original manufacturer of the Coil kit for Sammis. They used to make them, RRO used to sell them. Something happened business wise and Shaffers quit making the Kit. RRO made some changes and began to manufacturer their own kit. It has changed a lot over the past 2 years for the better.
Last summer Shaffers decided to get back into the market. They have a really nice setup out as well. It is a bit more modern but I don't assume that it performs any better since it is limited by the same ciol spring. Anyways you can see the Shaffer stuff at the link below. Hope this helps you out!
art
http://www.shaffersoffroad.com/
http://shaffersoffroad.com/catalog/product_info.php?cPath=58&products_id=328
Offline 1bigtracker
  • 3409
« Reply #14 on: August 27, 2004, 05:26:59 AM »
i'll have to stop you their.  Heim joints will ware out quicker than a lets say Currie Jonny Joint.  but i would just get a whole bunch of the onces the are in the lower control arms of trackers and use them as joints ;D
stu
  ÂÂÂÂÂÂÂ
