I have radiator fluid pouring out the bottom of the intake manifold!
Black Zuk
77
2
Top Down Cruse around and play in the dirt.
May 01, 2009, 11:28:32 AM »
This has to be a newbie question. I have radiator fluid pouring out the bottom of the intake manifold! is there a relief valve under there or do I have to start replacing hoses? it quit after a bit so I refilled the reservoir and it leaks just a bit. I'm guessing the thermostat is in-op so thats first on the to be changed list. Next I'm going threw the hoses....... Any other Ideas?
88' Samurai, Throlly Exhaust and Calimini cam so far
fuzzy1
350
7
It's not about hair, it's about the logic
Re: I have radiator fluid pouring out the bottom of the intake manifold!
May 01, 2009, 05:00:46 PM »
Guessing it's a Sammy by your ava pic? Not sure if they're similar to trackicks in this regard... but trackicks have a pipe under there that the hoses (heater & rad rtn) connect to... & an o-ring that's pretty common to leak shown here:
http://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/30593-coolant-leak-behind-water-pump.html#post166592
Maybe a sammy guy will chime in & confirm if they're similar setup. hth
Fuzz
Non Illegitimi Conterat
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
May 01, 2009, 07:29:56 PM »
theres ahose from that tube to the bottom of the intake. feel around you'll find it
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
idaholwb
772
2
And that's the way the metal crumpled!
Reply #3 on:
May 03, 2009, 06:16:23 PM »
The hose is a 5/16" heater hose. Normally there are at least 3 on a Suzuki engine regardless what size it is. Don't use fuel hose when you do it. Actually look around to as many parts stores in your area as you can until you find heater hose that size. Fuel hose can't handle the heat and coolant for long periods of time.
97 Sport
265/70-16s
2" lift
2.0 swap
Jeremiah
1880
Viva La ZUKIWORLD!
Reply #4 on:
May 03, 2009, 07:54:09 PM »
There's a few hoses around the intake / radiator. It's to help warm things up quicker. It's usually a couple bucks worth of hose to fix, but you'll need to feel around to find the leak (be careful if the engine's warmed up - the water will be hot).
Black Zuk
77
2
Reply #5 on:
May 04, 2009, 06:22:01 AM »
K I'm gonna try to fined the hose. It's a bit tight working on the intake side, it's still fun. Thanks I'll let you know how it works out.
oak_raid
193
2
Reply #6 on:
May 04, 2009, 07:58:47 AM »
If you remove the air cleaner assembly the hose is easily accessed.
Black Zuk
77
2
Reply #7 on:
May 05, 2009, 06:53:54 AM »
OK I couldn't find any tiny rad hose, I had a dummy at AutoZone tell me that fuel line is a better choice than rad hose? I had to leave...... it dose no good to get kicked out of Autozone.
idaholwb
772
2
Reply #8 on:
May 06, 2009, 12:10:20 AM »
Try a Carquest or NAPA if you have one close... If it's your DD and you need to drive it and they can order you some, use the fuel hose for now till the other shows and then change it out... Just don't leave it on for a long time...
97 Sport
265/70-16s
2" lift
2.0 swap
Jeremiah
1880
Viva La ZUKIWORLD!
Reply #9 on:
May 06, 2009, 11:35:00 AM »
The hose I had to replace could have been mistaken for a vacuum hose (in fact - I did mistake it for one, my friend spotted the right one). It was a little guy going to the carborator on "back" side (towards firewall).
