front driveshaft bolts came loose
  • 16 Replies
  • 4608 Views
Offline Luc
  • 51
« on: May 22, 2009, 12:17:29 AM »
I playing around on on a loading dock like immature kid i am, and i notices the front drive shaft bolts were loose, well the one that was there was anyway.
So other than just old age and rust, what else could have caused that?
I have a d-shaft spacer, but its the other end, by the t-case. The case hasn't been sounding too good for a while, needs a rebuild i think. maybe that?
I just don't want to think just tightening it up will fix it then have it blow up on the trail.
vitals:
86 samurai
1.3, spoa, 235's, stock gearing.
Re: front driveshaft bolts came loose
« Reply #1 on: May 22, 2009, 04:19:48 AM »
The bolts may not have been torqued up properly. Under tightening is an obvious problem but overtightening can also be a problem, the bolts can be stretched and weakened. The other issue is that the spring washers may have been worn out/crushed.
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #2 on: May 22, 2009, 08:12:05 AM »
I had that problem continually with my sami...figured it just must be driveshaft angles causing some vibration.  I found that a set of nylock nuts and lockwashers never came loose again...cheap fix
My rig is a fusion of Jazz and Funk; I call it JUNK
« Reply #3 on: May 22, 2009, 11:18:07 AM »
I have had mine come loose a few times, you just need to check them every once in a while.
Or go with sewerzuk's idea and fix it permanently.  But what is the fun in that.  :D  I would recommend picking up a set of drive-line bolts to keep in your tool bag.  Sammy's use the same bolts on all 4 corners, so one set will save you if you loose them.
« Reply #4 on: May 22, 2009, 05:50:24 PM »
Locktite with the proper torque and I've never had them come loose.
Offline Amilla
  • 1076
« Reply #5 on: May 23, 2009, 06:53:06 AM »
Blue Locktite all the way.
Amilla
Offline Luc
  • 51
« Reply #6 on: May 24, 2009, 02:27:42 PM »
I found the problem... my D-shaft spacer blew up.
I had two... one on each end. oops... :-[
« Reply #7 on: May 25, 2009, 08:18:09 AM »
As in it broke?  How did you break a chunk of aluminum?
« Reply #8 on: May 25, 2009, 09:27:09 AM »
 ??? How did you not notice the thing flopping around when you drove? It had to make some noise.
Offline Luc
  • 51
« Reply #9 on: May 28, 2009, 09:26:30 AM »
there was on bolt holding it together still, till i drove up the stairs.
« Reply #10 on: May 28, 2009, 12:58:39 PM »
Ah, that would do it.  Probably a bad casting.
« Reply #11 on: May 30, 2009, 09:17:12 AM »
Amilla
That reminds me - what's the difference with all the colors?
« Reply #12 on: May 30, 2009, 10:10:47 AM »
Amilla
Blue is made to be removable.  Red is made to be pretty much permanent, so it sets up harder.
« Reply #13 on: May 30, 2009, 10:11:52 AM »
Different bond strengths - the most common are blue & red - loctite blue is medium strength, loctite red is high strength.  Loctite red may require heat to break the bond, blue typically does not.
You can also match it to the fastner size - put loctite red on a small fastner and the bond strength could be greater than the stregth of the fastner itself, which will result in the fastner shearing if you try to undo it.
What I'd like to know is why does loctite blue come in a red bottle ?
« Reply #14 on: May 30, 2009, 10:15:22 AM »
I've wondered that too.....blue comes in a red container and red comes in a blue container. ???
