tracker only starting if gas poured into intake
  • 2402 Views
« on: July 25, 2009, 10:39:39 PM »
 i have 91 tracker it was running fine yesturday but wont start today it will start if i dump fuel down intake but only runs tell all that fuel is burnt up any ideas fuel pump maybe? ???
Offline fuzzy1
  • 350
Re: tracker only starting if gas poured into intake
« Reply #1 on: July 26, 2009, 09:12:19 AM »
Can you hear the fuel pump run (3 seconds at key on?) Usually takes 2 ppl, 1 with ear by filler neck, other to turn the key on... the pump should run for 3 seconds at key on. If it doesn't, I'd check the ground point for the fuel pump 1st. It's behind the driver side tail light... pretty common for it to get corroded & cause fuel pump fail.
Pic toward bottom of the page here:
http://www.kick-fix.com/INJECTORS/PUMP/dead-pump.html
hth
Fuzz
« Last Edit: July 26, 2009, 09:16:25 AM by fuzzy1 »
Non Illegitimi Conterat
Offline muskegtracker
  • 273
  • 10
  • Mr T
« Reply #2 on: July 26, 2009, 09:43:30 AM »
I had a similar experience...was rippin' around the farm yard and it just stopped.  If I poured gas down the TB it would run.  After messing with a ton of stuff, figured out the injector wasn't firing because a capacitor in the computer puked out its contents and melted the tracing in the board.  It was a 60 cent fix to solder in a new capacitor.  Not hard if you understand basic electronics.
You can visually check to see if that happened by pulling the computer and examining the larger cylindrical shaped component on the corner of the computer board.  If it looks like some stuff has leaked out...that is probably the problem, or will be soon.
These are a common failure on the older Trackers.  Mine is a 91 as well.
Of course with all things automotive, there are a variety of different things that could go wrong.  This just sounds like the most probable.
If it was a fuel delivery problem like pump filter, injector, I imagine it would have run intermittent or real crappy before it finally stopped.
Good luck!
« Last Edit: July 26, 2009, 09:52:34 AM by muskegtracker »
91 Chevy Tracker
