swap question
  • 42 Replies
  • 7912 Views
Offline captchee
  • 224
swap question
« on: August 11, 2009, 07:49:21 PM »
 Ok so .  I came a cross a deal today and  picked me up a 95 4 door  with 1.6 16 valve and 5 speed trany
 Why  this,,,, when I was looking for a  4 speed auto ?   Well I Got a good price .
 So now  my question . Is there any real issue with swapping this into my 89 2 door  that had a 1.6 8valed with 3 speed .
 I been looking for  threads on this  here on the forum ?? Maybe I missed it so if I did could someone  point me  to the right place .
 Otherwise , im thinking  all I really need is to swap  out  the peddles  , harness and ecm and center consol  into my 89 .
 Im running stock tiers  so  would there be any real issues if I left the gearing alone ?
Offline zukimoo
  • 330
Re: swap question
« Reply #1 on: August 12, 2009, 05:16:15 AM »
your housings are going to have 462 and the standard runs 512's. I'd swap in the 512's because they are already low on power and you don't want to loose any more power.
06 Baja Buggy
Offline captchee
  • 224
Re: swap question
« Reply #2 on: August 13, 2009, 11:53:57 AM »
 thanks , ill keep that in mind .
would the  complete  housings a derect swap as well ?. IE un bolt the complete front and rear  in the 95 4 door and just bolt it right up into my 89 ?
Re: swap question
« Reply #3 on: August 13, 2009, 01:41:54 PM »
You should be fine, I don't believe they switched the front end to the larger spline until 96.  And even if they did, you have all the spare parts you would need to switch over.  :D
Offline captchee
  • 224
Re: swap question
« Reply #4 on: August 13, 2009, 03:10:46 PM »
Re: swap question
« Reply #5 on: August 13, 2009, 03:32:12 PM »
http://www.acksfaq.com/driveshaftvideo.htm
If you do a search on AcksFaq for Driveshaft you can find lots of links going over the shafts.  He even has a Tracker manual for it.
http://www.acksfaq.com/96-FSM-v1-4a-pdf.htm
Offline captchee
  • 224
Re: swap question
« Reply #6 on: August 13, 2009, 06:07:34 PM »
now look at that . THANK you very much  8)
Re: swap question
« Reply #7 on: August 14, 2009, 06:29:06 AM »
Offline captchee
  • 224
Re: swap question
« Reply #8 on: August 14, 2009, 04:34:11 PM »
 nope ist all going to go , engine and trany . the lower end of the engine is toast .  the uper end is good , the ecm is good  the trany works fine , just high miles
 so im thinking once i get it all back together , ill put  whats good that im taking out , up on this forum for sale  ;)
Re: swap question
« Reply #9 on: August 14, 2009, 05:39:49 PM »
You could just pull the engine and leave the auto trans.
Swap the flex plate over to the 16V and bolt it up, otherwise
you could swap all the 5 speed parts over as well, we did a 5 speed
to auto conversion, not too bad, and as far as wheeling, I'd take
an auto over a clutch anytime. my $.02 worth
Offline captchee
  • 224
Re: swap question
« Reply #10 on: August 15, 2009, 01:16:26 AM »
Re: swap question
« Reply #11 on: August 15, 2009, 06:52:41 AM »
if your going only for mileage I would wait to swap out diffs. See what you think about the 462 and if you dont like it then swap to the 512
Offline captchee
  • 224
Re: swap question
« Reply #12 on: August 15, 2009, 04:48:01 PM »
 i was thinking the same  thing . ill need the car  so  i can try it out for a week or so and if i dont like it i can  do the swap
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: swap question
« Reply #13 on: August 15, 2009, 06:54:30 PM »
I am not positive that you are dealing with a Samurai here...
That said, if both trucks are TracKicks you should have no problems with driveshaft phasing as the driveshafts are single-piece units.  On the other hand, Samurais have two piece driveshafts and must be properly assembled if separated.
The Haynes Manual is great when used as a campfire starter ESPECIALLY when purchased for fixing a TracKick!
I have seen in the FSMs where they suggest that you mark the flanges so that you can re-assemble things to the way they came from the factory.  That's not a bad idea...
I hope that this helps and I hope that you found Ack's FAQ useful!
Ack
Offline captchee
  • 224
Re: swap question
« Reply #14 on: August 16, 2009, 01:45:34 PM »
ya Ack , your FAQ was great . been doing alot of reading .
 no these are both sidekicks . im going to take the 16V  and 5 speed out of the 4 door and put in my 89 . infact , im thinking i going to change the dash  seats , everything . i dont think the back seat from the 4 door will fit into my 2 oor , but the front will  im sure .
 my 89 also doesnt have power stearing so thats going over
