t-case gear noise?
  • 13 Replies
  • 3418 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
t-case gear noise?
« on: September 15, 2009, 05:22:37 PM »
i have an 87 sami   6.5 gears  I've put about 3000 miles on them took it to the coast this weekend on the way home the gears started the wine   checked gear lube level is full.
do the gears get louder as they wear in?
Offline DaddyDave
  • 204
  • Indeed
Re: t-case gear noise?
« Reply #1 on: September 16, 2009, 01:57:02 PM »
Whose gears are they?
US made or Chinese copies?
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #2 on: September 16, 2009, 06:43:51 PM »
i got then from low range offroad
Offline Amilla
  • 1076
« Reply #3 on: September 17, 2009, 12:44:08 AM »
If lowrange is where you got the gears, you probably have Trail Gear 6.5's.
The Trail Gear 6.5's seem to be a loud gear set.  I added some Lucas to mine and it quieted them down.
Amilla
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #4 on: September 17, 2009, 08:48:57 AM »
i will try the lucas      did u  use the synthetic?
Offline Amilla
  • 1076
« Reply #5 on: September 17, 2009, 09:45:49 AM »
I used the heavy duty oil stabilizer.  Before you go to add this stuff to your rig, I would suggest warming the hell out of the oil.  The stuff is so thick, its hard to get out of the bottle.  Especially  if your laying under your rig trying to squeeze it into your tranny or T-case.
So far i haven't found a pump that will handle Lucas.
Amilla
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #6 on: October 15, 2009, 10:29:50 AM »
found the problem i will post pics had a gear start losing teeth   time for a new set
Offline Amilla
  • 1076
« Reply #7 on: October 15, 2009, 10:33:38 PM »
Starting loosing teeth?!
Must see some pics of this!
Amilla
« Reply #8 on: October 17, 2009, 12:36:09 PM »
Amilla, how much Lucas do you use? In your tcase.
Offline Amilla
  • 1076
« Reply #9 on: October 18, 2009, 09:08:34 PM »
I put a little less than half a bottle in.
Amilla
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #10 on: October 22, 2009, 05:38:47 PM »
heres some pic's bearing went out to lunch and ate it all   lol
« Last Edit: October 22, 2009, 05:47:14 PM by fordguy79 »
Offline Amilla
  • 1076
« Reply #11 on: October 22, 2009, 10:28:20 PM »
Did you rebuild your T-case when you installed the gears? Or are they they stock bearings?
That's no good to see that they took a dump like that.  Did you talk to trail gear yet?
Amilla
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #12 on: October 22, 2009, 11:10:46 PM »
i reused the bearings  yes i was cheep!:(                I talked to sean at low range he said box them up and send then in he will send me a new set  so i need to order new bearings like i should have done in the first time                       live and learn    lol
Offline Amilla
  • 1076
« Reply #13 on: October 23, 2009, 06:40:40 AM »
Bummer to see the gears went south like that.
Its got to be nice that your getting a new set thou.  Just rebuild that bad boy and never look back ;D
Good luck
Amilla
