need help with brakes??? firebird MC conversion
  • 11 Replies
  • 2744 Views
Offline dres0081
  • 73
« on: September 21, 2009, 07:40:56 PM »
so i am finishing up my toyota axle swap and have a problem i dont quite understand. I Installed a early 80s firebird master cylinder to increase my braking volume as i am running 4 wheel discs on the yota axles (btw this is on a samurai), so anyways bleed through everything fine and have a very stiff pedal but very little for brakes. The pedal seems almost too stiff ive never had this problem before.
any ideas?
88 1/2 sami,yj springs spoa, 33s
Re: need help with brakes??? firebird MC conversion
« Reply #1 on: September 22, 2009, 04:43:46 AM »
Are all the calipers free and the wheels rotating correctly, if so then the m/c is too big.
Offline dres0081
  • 73
« Reply #2 on: September 22, 2009, 08:28:08 AM »
no when i do brake it will stop but is slow and weak.
Offline sir lance
  • 342
  • I love my XL-7
« Reply #3 on: September 22, 2009, 10:46:22 AM »
did you remember to hook up your brake booster?
Offline dres0081
  • 73
« Reply #4 on: September 22, 2009, 05:50:50 PM »
i never messed with the brake booster the just unbolted the stock sammy M/C and bolted on the flaming chicken one. the seal between the M/C and the booster does not seal the greatest could that be the problem.
Offline sir lance
  • 342
  • I love my XL-7
« Reply #5 on: September 22, 2009, 07:18:40 PM »
dont you have to change the length of the pushrod when you do a MC upgrade?
Offline dres0081
  • 73
« Reply #6 on: September 22, 2009, 07:21:15 PM »
from all the write up i have read on the swap no
Offline dres0081
  • 73
« Reply #7 on: September 30, 2009, 07:32:04 PM »
still cant figure this one out i checked my booster and its fine. the pedal barely goes down at all even when the truck is off im stumped? ???
Offline sir lance
  • 342
  • I love my XL-7
« Reply #8 on: September 30, 2009, 09:30:46 PM »
would the pedal go to the floor when bleeding?
Offline dres0081
  • 73
« Reply #9 on: September 30, 2009, 09:52:08 PM »
yes it would
Offline sir lance
  • 342
  • I love my XL-7
« Reply #10 on: September 30, 2009, 10:48:57 PM »
have a look and make sure your caliper sliders slide, a guy over on the grand vitara forum had the same problem, it ended up being both his caliper sliders where solid lol
Offline dres0081
  • 73
« Reply #11 on: September 30, 2009, 11:06:19 PM »
didnt even think of that and the axles i just stuck under my samuarai were sitting for about a year so thats a definate possibility.
