samurai with stock axles and 6.5:1 tcase, what gears for 33s??
  • 3918 Views
Offline klauss35
« on: October 18, 2009, 10:12:46 AM »
I'm using my sami as a daily driver (street and freeway) and a also as trail/light crawler truck with a 1.6 16v on it.
Thanks
Re: samurai with stock axles and 6.5:1 tcase, what gears for 33s??
« Reply #1 on: October 18, 2009, 01:15:24 PM »
If you go with Toyota axles 4:10 or 4:30, if you go with a hybrid rear Sammie axle with tracker third I would go with 4:30 ratio if you drive on the freeway and don't want to run at 5000 rpm's all day.
« Reply #2 on: October 18, 2009, 01:41:05 PM »
The 6.5 should bring you into stock gearing for the 33" tires in high range.  With the 16v you should have enough power to move the tires without any real issues.  Using a GPS to check your speed how far off is the speedometer, and are you looking for more power then you have now due to over-gearing or just trying to get the speedometer into spec?
Offline klauss35
« Reply #3 on: October 18, 2009, 03:26:28 PM »
Thanks, I'm trying to bring the rpms down, i been having dramas (overheating) running at 4000/4500 to keep the speed in the freeway, I'm running stock axles
« Reply #4 on: October 18, 2009, 11:36:27 PM »
In that case I have to agree with mrfuelish, but I would take a look at your cooling system first though.  I run 4K on the freeway in my Tracker on the freeway without issues and have climbed passes in 4th pushing those RPM's.
Offline Amilla
  • 1076
« Reply #5 on: October 19, 2009, 06:29:12 AM »
I run 4000 to 4500RPM on the freeway, some where in the range of 50 to 55 mph. Never gets hot, definitely look into your cooling system.  Does it over heat at any other time? Or is it just a freeway thing?
Amilla
Offline klauss35
« Reply #6 on: October 19, 2009, 08:42:48 PM »
thanks again, anyway I have to replace the radiator after the old one decides to die on me at the worst moment ever, now I'm running a new aluminum one with an electric fan (flex-a-lite), I haven't tested yet on the freeway.
Maybe I will try with a set of 4.57 and see how my sami can handle the street.
Thanks for the advice.
Offline Amilla
  • 1076
« Reply #7 on: October 21, 2009, 07:08:33 AM »
Nice Nice, I to have a flex a lite fan.
I have had my fan off for months now, the only real time I turn it on is when im in lowrange crawlin around.  Thats the only time the temp will come up.
Sounds like a good set up you got.
Your going to be increasing your RPMS with 4.57s.
Amilla
