fuel line
  • 1843 Views
Offline dupont#24
  • 48
  • Deer hunter
fuel line
« on: November 01, 2009, 05:09:52 PM »
Doing a 1.3 to 1.6 8valve swap on the fuel line what do I do.Do I cut the rubber off of the metal line and double clamp it to the inlet on the fuel line on the fuel injection can someone tell me
Offline captchee
  • 224
Re: fuel line
« Reply #1 on: November 02, 2009, 05:47:35 PM »
 well the FI uses a much higher PSI then you manual pump .
 you can get away with hose clamps on a lower  TBI   like a chevy 4.3   it only runs around 30 PSI .
BUT  the pump on both the 8V and 16  run 90+ lbs  as such its best to have   flaired line ends and pressure fittings to keep the leaks down .
Offline dupont#24
  • 48
  • Deer hunter
Re: fuel line
« Reply #2 on: November 02, 2009, 06:39:34 PM »
Thanks
Offline tipover
  • 422
Re: fuel line
« Reply #3 on: November 03, 2009, 12:37:18 AM »
yes cut it off and use fuel injection hose and clamps.   you can buy that at napa.  thats what Trail tough does.  ask brent.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline heiney.5
  • 175
  • 9
Re: fuel line
« Reply #4 on: November 03, 2009, 05:27:47 AM »
I agree the pressure is definitely high and pressure fittings would probably be the "best" solution....
However I have been running clamp with fuel injected rated hose for over a year now, and have had no leaks. I did flair the fuel line a little to help hold the hose and clamp.
