Guess what came today!!!
  • 31 Replies
  • 6311 Views
Offline explosivo
  • 3157
Re: Guess what came today!!!
« Reply #15 on: July 29, 2004, 06:02:08 AM »
Also, Wild, how have your LTB's worn? What kind of pavement life expectancy can I expect out of them (I'm hoping I'll be driving under 3-4k miles next year)?
omghi2.us[/url]
« Reply #16 on: July 29, 2004, 06:20:16 AM »
Get rid of those out side weights and have them put a weight patch on the inside :o
« Reply #17 on: July 29, 2004, 06:25:28 AM »
8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o
TO
NICE change
:o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8) :o 8)
Offline explosivo
  • 3157
« Reply #18 on: July 29, 2004, 06:36:19 AM »
The what now? I'm happy the way it is because they charged less than the Walmart tire and lube place I took the coopers to before :o
NICE change
Thanks ;)
I'm looking for a pic of my Tracker stock to do one of those "Before and After pics ;)
omghi2.us[/url]
« Reply #19 on: July 29, 2004, 06:57:51 AM »
Totaly off subject, out in left field BUT, How do oyu do the multpile quotes from different posts?
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #20 on: July 29, 2004, 09:56:44 AM »
Just copy the 'quote' and paste it in your reply. Highlight the text and hit the javascript button for insert quote. Rinse and repeat Zig!
steveo
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #21 on: July 29, 2004, 10:44:29 AM »
Holly wheel weights batman ;D
Looks sick mang
01 GRAND VITARA
Offline explosivo
  • 3157
« Reply #22 on: July 29, 2004, 11:31:15 AM »
I quote someone, write my reply, highlight everything, then click back and quote the next message I want to quote and paste in the previous one ;)
That's my method. Steveo's works as well ;) ;D
« Last Edit: July 29, 2004, 11:32:30 AM by explosivo »
omghi2.us[/url]
« Reply #23 on: July 29, 2004, 01:50:28 PM »
I thought they wear OK, but I try to
switch to street tires so I don't burn
up the off road rubber for driving to
work. I had to put the LTBs on the
front coming back from Moab, man
I couldn't get the front aligned, it kept
pulling, I'd stop and adjust, no change  >:(
So I just drove it home, chewed about
half of the tread in 800 miles  :'(
I need to re-groove the tread so it's
deeper again, but as long you keep
the alignment good, they wear alright,
just remember they are like a 30,000
mile tire, soft tread compound wears
faster than a good set of Radials
Offline explosivo
  • 3157
« Reply #24 on: July 29, 2004, 02:20:14 PM »
Damn... now I'm really considering taking my brother's advice and slapping the stockers back on for the 200 mile trip to school in a couple weeks :o
I did get a chance to test them out, and I found out that they like to dig... A LOT... got myself stuck because they dug a 16" deep hole in some soft gravel :o :o
I definately need lockers (and 4wd :().
omghi2.us[/url]
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #25 on: July 30, 2004, 04:29:26 AM »
were you going to school at man/\
« Last Edit: July 30, 2004, 04:29:43 AM by zookiemike »
Offline JokerWhiskey
  • 157
  • holy poop! a fuzzy bunny!
« Reply #26 on: July 30, 2004, 04:39:09 AM »
(and 4wd :().
;D ;D
« Last Edit: July 30, 2004, 04:39:55 AM by JokerWhiskey »
Offline 1bigtracker
  • 3409
« Reply #27 on: July 30, 2004, 07:35:47 AM »
if you think you have power loss now, you will have alot bigger one with lockers.  i would do a few power adders or gears before doing lockers.
stu
Offline explosivo
  • 3157
« Reply #28 on: July 30, 2004, 07:35:51 AM »
ITT Tech in Grand Rapids
omghi2.us[/url]
Offline explosivo
  • 3157
« Reply #29 on: July 30, 2004, 07:39:24 AM »
stu
Header's probably coming before lockers... Lockers are in the distant future. Like 1-2 years at the soonest :(
Also, when I dropped the truck off and picked it up, the exhaust had worked itself loose, so I drove it home with open manifold... As you saw in my thread last night, I put the exhaust back together, and it's much better now. Not too much different than the radials... but there is noticeable difference between the two still.
omghi2.us[/url]
