Another shock question
  • 3208 Views
SpinalTap
« on: July 24, 2004, 03:22:31 AM »
Hey All,
I am going to be installing a 1.5" coil spacer lift and was wondering if I should install longer shocks while I'm at it. I did a search and found that 2wd 99 F150 shocks seem to be a recommended mod but more for use with the Calmini 3" lift. Would they be too long for my application? Would the Crown Vic shocks be a better fit?
I also have a set of camber adjusting bolts coming so that it can be properly aligned afterward.
I'm lifting it up to clear a set of 235/75 BFG ATs that I'm having mounted on 15x7 AR767s.
Thanks much for any advice you have to offer  :)
Re: Another shock question
« Reply #1 on: July 24, 2004, 06:06:28 AM »
Use Crown Vic shocks for the rear,
F-150 shocks are too long even with
3" spring spacers in the rear, you need
to relocate the upper shock mounts
if you want to use those
SpinalTap
« Reply #2 on: July 24, 2004, 08:00:11 AM »
Thanks Wild :)
« Reply #3 on: July 24, 2004, 02:58:32 PM »
 ;D My pleasure
Offline Flight
  • 89 Tracker.. All stocked out
    • Carbs Unlimited
« Reply #4 on: July 24, 2004, 03:49:18 PM »
Spinal,
Let me know how that install goes.. I am panning that exact install on mine.. same tires, rims, and lift..
I hadn't thought about the shocks though... how badly do you need new shocks after that small of a lift...? is it highly reccomended if you plan on wheeling a bit? what about just street driving?
Thanks for any info..
Flight
89' Tracker
« Last Edit: July 24, 2004, 08:21:59 PM by Flight »
89 Tracker : White with Girly  purple pinstriping, K&N Filter.. and... Uhh.. 0" lift.. balding 205/75 tires on stock rims.
Offline Kreg
  • 795
    • Island 4x4
« Reply #5 on: July 24, 2004, 04:26:06 PM »
I think Mike made a mistake when he mentioned the 1999 F-150 4x4 shocks, because on a later note he told me that you need to get the 1999 F-150 2WD shocks. (I guess they are shorter than the 4x4 shock)
I still havent gotten around to doing the rear end mods yet, but I'll let you know how it turns out when I get around to it.
SpinalTap
« Reply #6 on: July 24, 2004, 04:50:13 PM »
Spiral,
Flight
89' Tracker
Who the hell is Spiral ;)
I don't think you need to replace the shocks for such a minor lift, but being as I'm going to have it apart I may as well swap out the shocks at the same time. BTW mine is mostly a pavement queen, but that's no reason not to improve its off-road abilities as well  ;D
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #7 on: July 25, 2004, 07:07:44 AM »
Hey guys im doingmy coil spacers today ill post some pics of it.
01 GRAND VITARA
SpinalTap
« Reply #8 on: July 25, 2004, 02:00:32 PM »
Great...looking forward to it :)
