pcv really needed?
  • 10 Replies
  • 3696 Views
Offline 90Stomper
  • 427
pcv really needed?
« on: July 15, 2004, 01:05:19 PM »
sorry i am full of questions today, but since i am working on the front end problem i figure i will go ahead and finish my snorkle.
is the tube going from the pcv to the al intake really needed or could i block it off.  i would like to get rid of the al intake tube and use a different system which i think will work real good except for hooking in that tube.  thanks all! :) 8)
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline idaholwb
  • 772
Re: pcv really needed?
« Reply #1 on: July 15, 2004, 05:04:52 PM »
 You would be much better off putting it back online. It controls the amount of oil vapor pressure build up in the crankcase....a.k.a. Positive Crankcase Ventilation.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #2 on: July 16, 2004, 12:33:40 AM »
I would think that if you completely blocked the PCV that you would cause oil leaks because of pressure against the seals, but I could be wrong.
Offline ChileKick
  • 75
  • DIYer Man !
    • Nacion 4x4
« Reply #3 on: July 16, 2004, 03:32:03 AM »
I blocked it once and smkoke started to build , obviously the oil starts leaking , what you can do is to connect the pcv to a separate filter totally independent from your snorkel
Custom 5" suspension lift,custom 2"body lift, custom transmision lift,custom intake porting and custom exhaust.
3" wider A-arms custom made front coils.Power inverter , dual batteries , 8000lb winch , VHF , AM , LSB , On board Notebook-GPS on 15" Screen :-)
 265/70 - 15 tires on 8 rims. Custom Man
Offline 90Stomper
  • 427
« Reply #4 on: July 20, 2004, 02:43:50 PM »
sorry been gone.  thanks all for the input!
this seems like a good idea, BUT is the neg. vacuum created by the intake important?  if it is not i could just run a longer hose off it up out of the way (lil snorkel) and put a filter on the end...? ???
mperry
« Reply #5 on: July 21, 2004, 02:29:39 PM »
You are correct... you could build a system similar to the pre-smog engines. (A snorkle tube came from the crankcase and hung in the airstream beneath the vehicle. They also used a vented oil filler cap. They used a metal filter inside the cap.)
The problem with these, of course, was all that blowby went into the air. It made the car smell of burned oil after a while. The engine oil also got dirty much quicker and engine life suffered.
Offline 90Stomper
  • 427
« Reply #6 on: July 22, 2004, 05:29:35 PM »
thanks mperry, that makes sense mostly.... why would the engine life suffer, it seems that the way it is set up now i am sucking oil fumes into the intake system.  wouldnt blowing it into the air be better on the engine?
Offline Cwkick
  • 888
« Reply #7 on: July 23, 2004, 02:29:14 AM »
That's the point.  It sucks the oil fumes in to burn them so your vehicle doesn't pollute the atmosphere.
With the tube just hanging there it will blow oil fumes out but also suck dirt in.
That is why you have the valve.  It is sort of a one way check valve.
Cwkick
Offline LawDog
  • 531
    • Emerling Chevrolet
« Reply #8 on: July 23, 2004, 02:57:59 AM »
I think mperry means that engine life suffers because of said crap that can get into your motor that way.  I would just leave it man, If it ain't broke don't fix it ;D.
Offline 90Stomper
  • 427
« Reply #9 on: July 23, 2004, 07:16:45 AM »
 ;Dgood points all ;D
Offline airmanwilliams
  • 913
« Reply #10 on: August 08, 2010, 06:59:18 PM »
thanks for the info on here everyone. I just got a samurai and have been going through it all and noticed the other day that the ind of my pcv was broken off and that the last owner just got a bolt and stuck it in the hole, I think now I will get a new pcv and stick a short filter on it.
1993 4door Suzuki Sidekick JX
