MSD Offroad Ignition
  • 3299 Views
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« on: January 21, 2010, 12:36:59 PM »
I was doing some searching around and stumbled upon this MSD - 6 Off Road Ignition System on the Rocky Road website under the Suzuki / Engine section..
According to MSD..
From idle to 3,000 rpm the MSD produces multiple sparks rather than just a single spark, which is a great benefit when you're crawling over rocks or creeping up steep grades. This spark series lasts for 20 degrees of crankshaft rotation and ensures complete combustion of the fuel mixture producing quick throttle response and a smooth idle.
The 6-Offroad will install to virtually any vehicle with a 12 volt electrical system and a distributor. It will connect to points, amplifiers or magnetic pick-ups on 4, 6 (even-fire) or 8-cylinder engines.
Can anyone say if this will work on the 2.0L Grand Vitara's with the coil packs? I know these vehicles doesn't have a distributor but i really like the design 'multiple spark' concept of the MSD offroad system..
What are your thoughts on the topic?
Thanks
Offline Rally_T-115
  • 117
Re: MSD Offroad Ignition
« Reply #1 on: January 21, 2010, 05:56:05 PM »
Right off the bat I'd say no.    You would need convert to a distributor style system.
However it does seem like an interesting idea and I think it would not be far to develop a kit that comes with 4 (or 6) MSD coils and plugs into the stock coil connections, it would just need an extra controller to watch when the ECM intends to fire a coil, and then in turn fire it multiple times.
James
1999 Suzuki Grand Vitara.
No lift or bigger tires intended.
Warn hubs. Air-SOTF circumvented.
Aftermarket4x4 front skid & fuel tank skid.  RRO Rockrails.
Waiting for: trans crossmember upgrade & skid. Contemplating: ARB rear locker.
Offline 3stagevtec
  • 204
« Reply #2 on: January 21, 2010, 10:34:11 PM »
I was hoping i was wrong about needing a distributor to get this to work.. Thanks
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #3 on: January 25, 2010, 03:18:00 PM »
this system will work on your truck but why you have sequential coil packs. and the msd is waste spark. So what this mean is on a sequential it fires before the power stroke on each cylinder per power stroke. Waste spark fires 1-3 and 2-4 at the same time. so you wear out part faster.
Why is it that you want to go msd ? There is no way even with a turboed motor making 400whp will you max out the stock smart coil packs.
01 GRAND VITARA
Offline Rally_T-115
  • 117
« Reply #4 on: January 26, 2010, 05:59:20 PM »
Actually this particular system states that it uses a distributor.
Some waste-spark engines (Ford minivans come to mind) come from the factory with "forward" platinum plugs in the front bank and "backwards" platinum plugs on the rear bank, (the platinum tip is actually on the side electrode instead of the center).  A bit cheaper than using double-plats all around.  This way the plugs wear out evenly.   Waste spark works differently simply to reduce the amount of coilpacks on an engine without having to go to distributor (reliability).
Exactly.  I know some old TurboDodge guys running 30+psi boost still using the stock coil and wires.  Don't upgrade untill you really need it, it's suprising how far the stock ignition system will go.
I think it was the mult-spark gimmick, not the power.
James
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #5 on: March 11, 2010, 07:29:32 PM »
Off the wall, especially since I have a 90 Tracker, I was just exploring the Vitara section and saw this.  I have a 2003 Chevy Silverado 1500, Z71, w/ 5.3L V8.  I added the MSD ignition coils and the wires...didn't notice anything.  No MPG gain/loss, no power difference to be felt (although I THINK it felt a little stronger when I was getting on a freeway onramp and punching it, it seemed to take off better from 4,000RPM and up.  But that's a lot of RPM).  I'd like to say I noticed a slightly smoother idle, but that could be because I changed out my spark plugs at the same time ::) And, they were expensive as hell.  I'm rather disappointed in my decision to buy them...it was stupid.  I use the truck as a daily driver and occasional light-duty towing, if any, and hardly anything offroad I would even consider close to "hardcore."
I think they were way more performance-based than my scenario.  I'm sure they work better on high-performance engines and/or people that race their trucks.
Recommendation:
James
What he said.
