Samurai IQ test?
  • 4061 Views
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
Samurai IQ test?
« on: June 03, 2005, 09:04:52 PM »
With just 4.62's and 31's, my  speedometer reads 56 when the GPS says 50.
After adding a GRS II a couple weeks ago, I did the following math:
31's            -- about 11 % higher
4.89 GRS II -- about 18 % lower high range
4.62's         -- about 23 % lower
total           --  about 30 % lower
Hmm 30% lower? Engine spinning 30% faster than stock, 4000 RPM at 58? So that means the speedometer reads 60 when GPS reads 42, right?  Whats wrong with my math?
My first test drive with the GRS II and my bad math, I was passing traffic wondering why everyone was going so slow. I got real lucky when the ricer blew past me and lit up the speed trap a couple blocks before I got there.
« Last Edit: June 03, 2005, 09:07:26 PM by zutefisk »
87 Samurai
Offline bandit86
  • 1641
  • elv8rguy
Re: Samurai IQ test?
« Reply #1 on: June 04, 2005, 02:18:11 AM »
tell me the stock tire size, stock gears, tcase gears and
I can do the math...
better yet, your speedo is out cause it's old?
« Last Edit: June 04, 2005, 02:19:07 AM by bandit86 »
« Reply #2 on: June 04, 2005, 03:42:17 AM »
I think you would multiply not add. say your high range is 1.8   1.8x3.73=6.714   1.8x4.62=8.316  because your high range is not 1to1 like most your final will always be diffrent from the others. to simplify your speedo is hooked to your transfer case, so your gear change is not a direct ratio change it has to be multiplyed by 1.8 to get the diffrence in gear change.
« Last Edit: June 04, 2005, 03:53:44 AM by mrfuelish »
Offline zutefisk
  • 124
« Reply #3 on: June 04, 2005, 06:53:07 AM »
Everything works just fine except the interface between the seat and steering wheel.
The problem is not really in the addition or multiplication.
87 Samurai
Offline bandit86
  • 1641
  • elv8rguy
« Reply #4 on: June 04, 2005, 07:18:14 AM »
hes right about the multiplication
Offline zutefisk
  • 124
« Reply #5 on: June 04, 2005, 01:54:57 PM »
Should be multipling, not adding, but the real trick is that the speedometer runs off the tcase output shaft.
You only include tires and differential when calculating speedometer adjustments
You include tires, differential, tcase, and transmission when you want to calculate to real speed to RPM.
With GRS II and 4.62s, Tachometer reads 30% plus higher than stock, while the speedometer still reads 12% high.
87 Samurai
Offline Utah_Tracker
  • 179
« Reply #6 on: June 05, 2005, 04:12:13 AM »
Wow that sounds complicated :P
 Now I may be cheating, but I would probably just go out to one of the 12 cops that lives in the neighbor hood and offer him a few donuts to tell me how fast I'm going when my speedo says certian speeds.   ::)
 I could probably get away with that as I am one also.
Utah
91 soft top Tracker, 3' Calmini Sup, locker around, Auto, & no Power Steering
GO BIG or GO HOME
Offline GeoB
  • 11
« Reply #7 on: June 05, 2005, 12:45:04 PM »
What he said.  Believe him.
And crawl.
GeoB
"The liberty of a democracy is not safe if the people tolerate the growth of private power to a point where it becomes stronger than their democratic State itself.
That, in its essence, is Fascism - ownership of government by an individual, by a group or by any controlling private power."
                                                         --FDR
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #8 on: June 05, 2005, 03:20:59 PM »
My math says you need bigger tires to fix the problem! ;D
Mike
