everyday driver????
  • 2085 Views
everyday driver????
« on: March 22, 2010, 08:24:38 PM »
Well I'm new to this forum, question is I'm currently looking into buying a samurai. I want to make it an everyday driver / part time wheeler. i want to know what mods ill need to do 70mph on the highway and creep up and down hills. any information will be helpful.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: everyday driver????
« Reply #1 on: March 22, 2010, 09:01:38 PM »
Well I daily drove my samaruai 100 miles round trip for 4 years to and from work everyday. I also took it wheeling... but it all depends what you are going to do with it.  Mine I did a spring over lift and ran 31x10.5's... You lose 5th gear because of the lift, and tire size so if you run stock gearing you will on windy head wind days not be happy.. 50-55mph top on those days.  My 2nd samurai I did the same but added tracker gearing iwth 4.62's in the diffs and I loved it.  I also down the road added a weber carb which gave me some extra power.  Some small things you can do for more HP or free up RPM"s are KN airfilter system (I made my own.) and a underdrive pulley if anyone still makes them.  Otherwise your going to need gearing in axles or T-case or both depending what you do with the rig.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #2 on: March 24, 2010, 07:26:07 PM »
Having daily driven both a Sami and a Tracker, I would recommend going with a Tracker.  It has more power for the street, and can do some respectable wheeling with only a spacer lift and 235's.  It is also a much more comfortable ride, and the velcro on the top doesn't blow off each time a truck passes going the other way on a 2 lane.
Jim Z.
66 Apache camper
Offline my996duc1
  • 222
« Reply #3 on: March 25, 2010, 08:25:03 AM »
My buddy daily drives his Samurai (5 days a week to work and back). He is running about 80 miles round trip.
He is running a Petroworks swap 1.6 16v motor, GRS II gears, 33" tires in his 1986 tintop.
He is totally happy with his setup.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline SnowSammi
  • 31
« Reply #4 on: March 27, 2010, 09:57:18 PM »
MY 87 STOCK GEARS WILL MAX AT 60-65 LEVEL FREEWAY, 50-55 SLIGHT GRADE AND PULLING
HILLS TO MY HOUSE 4,000FT.  45-50 NO HEADWIND FORGET 5TH GEAR!
ON MY LIST THORLEY HEADER & 2'' EXH. AND INSTALL MY TRANSFER CASE GEARS.
« Last Edit: March 27, 2010, 10:01:05 PM by SnowSammi »
87 Samurai: OME springs & shocks, 30" Cepek mountain cat tires, K&N air filter, 6:4.1T-Case gears.
