samurai axle relocate
  • 3079 Views
Offline 87zukini
  • 35
« on: March 23, 2010, 09:18:00 AM »
ok guys i have all my parts to start my yj swap but as im looking what have you guys done to move the fuel tank back to clear the axle. im using a tracker tank and have not yet decided how far im going to move it but am looking for ideas /problems others have had. any help would be great
thanks
Re: samurai axle relocate
« Reply #1 on: March 24, 2010, 12:21:10 PM »
When I changed the suspension around I didn't move the tank at all, just accepted that I could only move the axle back an inch more then the stock position.
If you want to slide it further back I would look at adding a fuel cell, that way you can get one specific to your dimensions.  An alternative would be to get a body lift then move the tank up as well.
Offline idaholwb
  • 772
« Reply #2 on: March 31, 2010, 08:43:46 PM »
 If you have one of the many YJ spring kits available on the market, you shouldn't have to move your tank at all... And why did you put a Tracker tank in yours? Unless it's from a 4 door, it is only slightly larger.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline 87zukini
  • 35
« Reply #3 on: April 01, 2010, 06:13:12 AM »
the tracker tank has the fuelpump to run my 1.6 16v and i am not using a kit i am making my own brackets
