Geo vs. Crown Vic...guess who won
  • 37 Replies
  • 9694 Views
Offline TopHeavy96
  • 488
« on: April 04, 2010, 03:48:54 PM »
Well, the Tracker is out of commission for a while.  Yesterday, on the way to the local trail/play area got nailed HARD by a dude in a Ford Crown Vic while pullin into a gas station.  >:( :'(  According to the Sheriff, I'm at fault for failing to yield, even though he was speeding and it looked like I had way more room than I did.  I AM SO RELIEVED my passenger wasn't hurt, as we had the doors off (seatbelts work? ??? who knew?).  Fortunately my bro said I can use his Jeep to get to work for a while.  I got a local boneyard that has a sidekick 4-door, I need the right rear lower link bracket/body mount(ripped away from frame), one axle shaft (bent at wheel flange I think), driveshaft, and maybe(hopefully not) the axle housing(looks like it may be bent right at the end of the Calmini truss).  Not to mention my nice new KYB mustang shock that's bent like a boomerang.  My driveshaft pulled out of the T-case and fell on the road when the suspension bracket broke, that in turn broke the rear U-joint, and mangled the heck out of the slip yoke.  Planning on buying the axle shaft, driveshaft, and frame bracket first to get the car drive-able then decide if I need to replace the housing.
 I'm hesitant to grab the parts though cause I know what a pain it is to find the right parts for these things.
 The main question I have for the pros here is, will I be able to take the axle shaft out of the pre-95 4-door(OBD-1, 1.6l, 16v) and slide it right into my '96. Also, if my housing is bent, will the gears in my car fit into the housing in the 'yard?
Thanks in advance for any help, and sorry for the stoopid questions, just need to get a little direction and moral support.
Thanks again, Matt
P.S. This Tracker will NEVER go to the crusher!  We will prevail!
« Last Edit: April 04, 2010, 05:54:36 PM by TopHeavy96 »
Re: Geo vs. Crown Vic...guess who won
« Reply #1 on: April 04, 2010, 07:24:05 PM »
Yes, your third will fit the housing that is in the yard.
If you want to use a pre 96 axleshaft in your 96, you are going to need the brake drum too.  The 89-95 trackicks have a brake drum that bolts onto the end of the axle, and the wheel studs are pressed into the brake drum.  On the 96s the axle flange has the wheels studs pressed into it and the brake drum slides over the studs.
I am not sure if the backing plates are the same between the pre 96s and the 96s and up or not.....so there is a possibility you will need the backing plate too.
Offline TopHeavy96
  • 488
« Reply #2 on: April 04, 2010, 07:43:46 PM »
Thanks for the info Skyhi,  I didn't think of the drum, I thought the 4-doors all used the slide on drums!  Well, it's lookin better for the little Tracker,  so glad my third will work in the junkyard housing.  Gonna get under there tomorrow on lunch and see what else is messed up.
Thanks again, and I'll keep y'all posted on the Tracker's return to glory!
Offline jawman
  • 406
  • 1234
« Reply #3 on: April 04, 2010, 07:57:16 PM »
THAT SUCKS!!! on my 93 4dr. the drums sliped on the wheel studs and the wheel studs were pressed into the axles.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
« Reply #4 on: April 04, 2010, 08:00:37 PM »
Must have had an axle swap done at some point then.
Offline v-stone
  • 625
« Reply #5 on: April 04, 2010, 08:50:17 PM »
Ouch! If you were closer I'd offer some help and parts.
SAS Tracker! No looking back now.
Offline keith
  • 1176
« Reply #6 on: April 06, 2010, 09:07:54 AM »
Cool, four wheel steering.   ;D
Hope you are back on the road soon.
« Last Edit: April 06, 2010, 09:09:33 AM by keith »
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #7 on: April 07, 2010, 01:10:42 AM »
OUCH  :o I hate it when stuff like this happens because of someone else who is speeding  >:( same thing happened to my sister in her 93 2dr fullsize Chevy Blazer (2dr tahoe), got hit because she had more than enough room if only the guy was obeying the speed limit.
Hey that sticker on the back, shouldn't it say "If you can read this, you must be driving a jeep"  ???
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
« Reply #8 on: April 10, 2010, 10:10:54 PM »
Yeah, I hate when that happens! It's sometime hard to judge oncoming traffic's speed. The term in traffic-speak is "traveling faster than the speed of sight". Think of it this way... you're backing out of your driveway. You stop, look both ways and decide you can make it out of the drive before that oncoming car that's a quarter mile away can get to you. Only problem is, that car is a AATop Fuel Dragster and he's gonna be here in 4.3 seconds going 300 MPH!
« Last Edit: April 10, 2010, 10:12:27 PM by dustybadlands »
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
Offline TopHeavy96
  • 488
« Reply #9 on: April 11, 2010, 12:17:03 PM »
Been doin a little dis-assembly on lunch breaks, slow goin cause I too lazy :sleepy:.  Gonna try to pick up the axle, bracket, and shock this week. Hoping to be able to put new U-joints in my d-shaft and roll with it, otherwise I'll have to get the shaft from the yard and swap my output shaft yoke.  More pics of the carnage:
Offline lostsheep
« Reply #10 on: April 14, 2010, 10:23:12 AM »
OUCH! honestly looks better then i thought it would be vs a big car like a crown vic. good luck with the resurection
1991 chev tracker, 350chevy, SM465 4spd manual trans, toyota axles, 4.37's welded rear, 35x12.50R15 all terrains
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #11 on: April 14, 2010, 02:46:30 PM »
Maybe you can just borrow the rear shocks from the crown vic since it must need a few repairs also......  ;)
Offline TopHeavy96
  • 488
« Reply #12 on: April 14, 2010, 08:13:44 PM »
Hey guys, thanks for the moral support!  Yeah the Tracker came out of it ok considering the smack it took, the rim and axle absorbed the impact a little.  Tux that's not a bad idea,  ;)  I got a little more work done, axle's out, third's out, output shaft yoke is cleaned up, its dust cover straightened up and welded back on.  Got the "F"ed up U-joints out and the driveshaft cleaned up, need to get the part that bolts to the pinion flange, mine's screwed beyond repair.
  Another question, ::) I believe I've read that they changed the axle splines from 22 to 26 in '96, does that mean I'll have to use the side gears out of the replacement axle in my third?  Or am I thinkin of the front splines? Here's some more progress:
Offline TopHeavy96
  • 488
« Reply #13 on: April 14, 2010, 08:15:27 PM »
Don't worry those are ANSI Approved cinder blocks  ;) :laugh:
« Reply #14 on: April 14, 2010, 08:47:51 PM »
That's the front axles that went from 22 to 26 splines
